18" SSR comps
Old Aug 5, 2003 | 03:18 PM
mike schramm's Avatar
18" SSR comps
I've read a post in the past where it was theorized that 18" x 9.5 SSR comps with 50offset would fit front and back with stock diameter springs. Is this a proven fitment, has anyone tried it.
mike
Old Aug 5, 2003 | 04:28 PM
93 R1's Avatar
Yes.
I have that exact setup as per Manny's(sleepr1) advise. It works beautifully. No rubbing at all. Just make sure to use 265/35/18's.
My car is a R1 though, not sure if the stiffer springs help or not.
Old Aug 6, 2003 | 01:46 AM
Mean Machine's Avatar
Originally posted by 93 R1
Yes.
have you got any pics??
Old Aug 6, 2003 | 07:10 AM
93 R1's Avatar
pics here
Old Aug 6, 2003 | 09:48 AM
Thats awesome! thank for the reply.
mike
Old Aug 6, 2003 | 09:51 AM
93 R1's Avatar
no problem
Old Aug 6, 2003 | 11:57 AM
the_glass_man's Avatar
Will u do me a kindness?
Can you run 17X9.5 with 265/40/17's all around as well???
I've got coilovers if it matters.
Old Aug 6, 2003 | 01:00 PM
93 R1's Avatar
I *think* so. Pretty sure you need 255/40's and a 50 offset though.
Manny will know.
Old Aug 6, 2003 | 01:33 PM
rynberg's Avatar
That should be fine, glassman. You will need close to +50 offset up front.
Old Aug 6, 2003 | 03:24 PM
Wow those are pretty hot!
thanks for the pics
Old Aug 7, 2003 | 07:39 AM
SleepR1's Avatar
265/40-17s might be a tad tall. If you can get the wheels in 50-mm offsets, you should be ok though.
You only need 2.5-inch coil springs if you plan to do 10 wides x 18 diameters all around with 285/30-18 tires.
Talk to John Purner @ Complete Custom Wheel for 50-mm offset 9.5 x 17 wheels.
FWIW the Comps are only available in 42-mm offsets for 9.5 wide x 17 diameters. You'll be limited to 255/40-17 tires for proper clearance up front.
Old Aug 7, 2003 | 12:18 PM
93 R1's Avatar
I know it was something like that, Manny.
Go with the 18's
Old Aug 7, 2003 | 01:24 PM
SleepR1's Avatar
Go with the 18's
Yeah the 9.5 x 18s come in 50-mm offsets. You could run 265/35-18s
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
