rear coilovers for 1st gen
Old Aug 5, 2003 | 05:06 AM
lenh's Avatar
anyone know where i can get a set of rear coilovers for my 85 thankz
Old Aug 5, 2003 | 06:46 AM
Aico's Avatar
I do not believe they exist.
Old Aug 6, 2003 | 07:55 PM
twistedriver's Avatar
Finally I have LSD
not sure if any one made coilovers for your first gen but ground control makes trimable springs for your rear end. http://www.ground-control.com/
Old Aug 7, 2003 | 11:42 AM
adam c's Avatar
Cheap Bastard
If you are trying to lower your car, just cut the stock springs back a little bit. They will still work fine. Start by cutting 1/2 of a coil circle. Cut from the bottom of the spring. You will need a spring compressor to remove them if they are still the stock springs. If you try to cut them with a hack saw, it will take you 3 days.
Adam
Old Aug 7, 2003 | 11:04 PM
revn247's Avatar
ISC racing has some threaded perches that sit above the spring. Basically like a weight jacker type of thing. I got them w/ the 125# springs for the rear. I'm currently trying to get my car corner weighted properly. Email me for their info.
In fact, Brad Page uses them too.
matty
Jan 18, 2020 10:39 AM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Marty RE
Aug 13, 2015 11:19 AM
