camber problems...
Old Jul 31, 2003 | 09:49 PM
onepointone's Avatar
i say what i want
camber problems...
a while back in my attempt to "drift" i over corrected and slid into a curb. ive since then learned to try this in a more "open" area, but i have a problem. my passanger front tire (one that got hit) is off camber. its .5 degrees out (ive had it on a machine) and the driver side is -1.5 roughly. its noticable in turns right hand turns are "stickier" than left turns when going at it hard. anyways...
the camber things at the top are all the way out on the top of the strut tower, i was thinking about going gc coilovers since they had the adjustable camber/caster plates. good idea? what do yall think would be an easy fix? i dont plan to autox this car MUCH longer, but i do want it to be fixed.
Old Aug 1, 2003 | 12:25 AM
REVHED's Avatar
Hunting Skylines
Most suspension shops over here can do strut corrections where they bend the strut in the appropriate direction to correct the alignment. Also allows you to dial in a bit of extra camber. Maybe look into that?
Old Apr 4, 2006 | 08:57 AM
skizzle84's Avatar
I seem to be real well at bringing up these old threads!! Anyways, EXACT same situation for me as above. Anymore suggestions you guys have? Est price? Please respond I need help!
Old Apr 4, 2006 | 10:47 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
First off, drifting on the street is stupid and you should have your license taken away, preferably for life.
Also a big badge that says 'I'm a ******* retard' should be permamently afixed to your forehead.
If you want to **** around with your car, go to a local Solo II event, pay your entrance fee and dorifto around that course to your heart's content.
Retard.
Ok, now that I've got that out of the way, you could have a bent strut or lower control arm and you probably mangled the tie rods as well. Good news is that the tie rods are cheap to replace, the strut and the control arm not so much unless you find a good unit in the salvage yard. I wouldn't trust a shop to rebend the strut myself and I don't know of any in my area that would do such a thing. SOP here is to replace the damaged unit, not stress it further by more bending.
Old Apr 4, 2006 | 11:00 AM
OnlyOnThurs's Avatar
TACOCAT
DRIFTING EXISTED BACK IN 2003 ?!?!?!? OMGWTFBBQ?!?!?!?!?!!
lol
Old Apr 4, 2006 | 11:45 AM
skizzle84's Avatar
First off, I didn't realize people could be such ******* *********. How about the wreck took place in an isolated area, and I wasn't driving.
******* *******, learn how to respect others, and to not use "retard," for it may offend some people.
BACK ON TOPIC
It is my camber that is bent. I fixed the control arms and other suspension parts myself, along with the help of a mechanic. Anyone have an estimate of how much it would cost to get fixed?
Old Apr 4, 2006 | 12:04 PM
gigglesnirt's Avatar
oonce oonce
Retard.
locally they're starting to not let drifting take place at solo2 anymore, and there are no drift days or anything out here so i dont see how they're going to do it any other way.
Old Apr 4, 2006 | 01:00 PM
Tranquil's Avatar
Wankle Waffles
Guys, forget about the whole drift thing. That's a moot point. Skizzle was just just asking for other ideas.
Are you sure you didn't slightly bend the part of the axle behind the brakes/hub? Its really hard to do but I've seen it done before and it threw off everyone that looked at it since everything else was straight.
Old Apr 4, 2006 | 03:00 PM
Kentetsu's Avatar
The top of the strut has an adjustable plate used for setting the camber. However, if this change was due to striking something, then you bent something. Replace the bent part for the "proper" fix.
Old Apr 4, 2006 | 03:55 PM
trochoid's Avatar
Old Fart Young at Heart
Camber can't be bent, it is a measurement. The rest of you post is confusing, did you, or did you not fix the parts?
If your camber is out, you have bent either: strut tube, spindle, lower control arm, rim or in worst case, the the engine cross member and frame. If you are not sure which part is bent, replace the strut assembly, spindle and lower arm.
Old Apr 4, 2006 | 10:16 PM
Driftlanta's Avatar
I didntt read any of the above. Most likly cause is a bent strut, I've been through atleast 5 of them from nailing curbs. They bend super easy. When you bend a control arm you will know, it bends like a boomerang at the strut rod bolts.
Spirit Rx-7
Mar 14, 2016 12:36 PM
imitek
13
Oct 28, 2015 10:57 AM
Barry_Beef
Sep 22, 2015 06:36 PM
