Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
backwards rotary swap
Old Jul 23, 2003 | 06:40 PM
CrxSivtecZ6's Avatar
i am looking to put a 13b in my 1st gen crx. i plan to use the 1st gen rx7 rear end. will the gearing in the 13b tranny work with the 1st gen rear end? also, how capable is the 12a? im sure i could get one of those a lot cheaper. i also plan on using a carburator. i know all the crap that is gonna go into putting it into the car, so whatever you can tell me about the rotory parts would be helpful
Old Jul 26, 2003 | 12:20 AM
oh man where to start? well i dont even know but i do suggest that you brush up on how front engine rear drive cars work and then think if its worth it to have someone retrofit it into a crx
Old Jul 29, 2003 | 07:09 PM
i hope this doesnt come off in a bad way, not my intention at all. i know how front engine rear drive cars work. thats what i got started in when i was a lot younger. i have just gotten into imports the past few years and have a pretty quick 91 crx as a daily driver, but now want to do something crazy with my 86 crx.
i think for now i am gonna have a tranny adaptor made and put the 13b in with the stock tranny and keep it front drive to work out the kinks with a rotary powered crx. after a while of playing wiht that i will work on making it rear wheel drive.
i would still appretiate and helpful hints on what to do with the engine. i have a pretty good idea how the engine mounts are gonna go, i mostly want info on running a carbed 13b. i have never run a fuel injected engine with a carb. i have heard of a kit to use a holly 4 bbl carb on it. how streetable is that? what about the distributor? will the 12a one work? thanks in advance for the help and no bashing
Old Aug 21, 2003 | 01:06 AM
Sk8r_dude's Avatar
Zoom - Zoom...
if you use a gls-se (1st gen) 13B tranny and rear-end everything should be fine.
Old Aug 21, 2003 | 05:05 PM
i dont really get what you are saying. i thought the 1st gen had a 12a and the 2nd gen had the 13b. i want to use 1st gen rearend, but 2nd gen engine and tranny
Old Aug 27, 2003 | 09:58 AM
CARLiTO_'s Avatar
isn't a crx front wheel drive?
Old Aug 27, 2003 | 05:55 PM
the late model 1st gen GSL-SEs has 13bs if im not mistaken..
Old Aug 27, 2003 | 07:32 PM
yes
originally posted by AE_Racer the late model 1st gen GSL-SEs has 13bs if im not mistaken..
did it still have the solid rear axle?
Old Aug 27, 2003 | 07:34 PM
yes
originally posted by AE_Racerthe late model 1st gen GSL-SEs has 13bs if im not mistaken..
Old Aug 27, 2003 | 07:37 PM
yes, it is front wheel drive
does that gsl-se have a solid rear axle too?
Old Aug 28, 2003 | 05:49 AM
Not sure...search in the 1st gen forum...
Old Sep 4, 2003 | 09:59 PM
hornbm's Avatar
FD > FB > FC
yes the GSL-SE has a solid rear axle too.
Any N/A rx-7 transmissions will bolt up to any N/A rx-7 engine. Doesnt matter if its a 12 or a 13b. You can use a 12a tranny with a 13b motor.
The GSL-SE did come with a fuel injected 13b motor.
As far as converting to carb goes, you need to get the fuel injector plug kit from racing beat.
However instead of doing that, if you are going carb, it might be worth while to make a 4 port 13b motor. This can be accomplished simpliy by using some 12a sideplates and intermediate housing, GSL-SE rotor housings (second and third gen ones wont work because they moved the water seal groove) Any 13b rotors of your choice, and a 13b eccentric shaft. Give that thing a nice port job and you have got one powerful engine. More info on this can be found in the 1st gen section, as mroe people make 4 ports in there.
Hope this helps.
1993fd3sracer1
Aug 31, 2015 07:14 PM
