my spedo n tacho dont work......
Old Jul 18, 2003 | 12:36 AM
rotarypwr85's Avatar
both dont work so what could be the problem?
Old Jul 18, 2003 | 02:09 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Sounds like an electrical short or loose wiring somewhere. Most tachs are controlled by the leading ignitors. Try checking the wiring. Trace the tach back to the ignitor.
Old Jul 18, 2003 | 09:27 AM
enigma32's Avatar
The speedo, on the other hand, is likely to be an issue of a bad cable or a bad [I forget the name of the part] in the transmission. (Or just a bad speedo =)
Check when the cable connects into the back of the cluster and where it connects into the transmission... If it's connected in both places disconnect it in both and try spinning it.
Old Jul 18, 2003 | 10:06 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Weird both would be out at the same time...Do the rest of your cluster gauges work?
Old Jul 18, 2003 | 10:27 AM
yea the temp and the gas gauge work and all the other lil ones
Old Jul 18, 2003 | 06:47 PM
The_7's Avatar
Registered Piston Eater
im pretty sure the tach runs off the trailing igniter
Old Jul 18, 2003 | 07:24 PM
hornbm's Avatar
FD > FB > FC
it does, its the negative lead of the trailing ignitor
Old Jul 18, 2003 | 08:56 PM
Yeah sorry I meant trailing not leading. It was 3 in the morning and I shouldn't have been posting.
Old Jul 18, 2003 | 11:03 PM
The_7's Avatar
its awl good
mattyL
Nov 21, 2006 06:51 PM
rotary emotions
European Forum
May 29, 2006 11:11 AM
driftaholic
Feb 26, 2004 11:20 PM
Rotary Racer
Aug 28, 2003 02:23 PM
