high mileage FD bad idea for auto-xing?
Old Jul 14, 2003 | 12:27 PM
jeff8932612's Avatar
Hi I have a '93 FD Touring with 111,000 miles. I drive it every other weekend or so and am planning to turn it into a strictly auto-x car. Would constant auto-xing be a bad idea for an FD with high mileage? Or should i buy a lower mileage FD for this purpose? Thanks alot.
-Jeff
Old Jul 14, 2003 | 01:13 PM
rynberg's Avatar
Why would it be bad? Just make sure your suspension and brakes are in good shape. If you have ANY original suspension pieces (shocks, bushings), they are long overdue for replacement. Other than that, go for it.
Old Jul 14, 2003 | 04:59 PM
redrotorR1's Avatar
LS6 Convert
You'll just get to the replacement point a little faster. My bushings have given up the ghost and and are crying for retirement. Toe links and trailing arms are creaking and groaning at me all the time. I'm at ~114K miles ... and between me and the original owner, this car has been auto-x'ed for a majority of its life. So maybe I wouldn't have had to do this for another 30-40K miles if the car wasn't auto-x'ed so much .... oh well.
Old Jul 16, 2003 | 11:59 PM
skunks's Avatar
I'm a CF and poop smith
compression test it, if it comes back good, i see no reason not to use it for autoX other then you might need a new suspension system
Old Jul 17, 2003 | 02:59 PM
HeatTreated's Avatar
Hi Powr FD's
Few things to keep in mind..
Keep atleast 1/4 of a tank when racing,
try to keep it cool during this summer heat (ie. Fan Mod, Water Wetter)
Stock IC heatsoaks easily, other than that, no problemo ~ go kick ****
Old Jul 17, 2003 | 04:27 PM
thanks for the input guys. I guess the 7 will have to endure alot of auto-xing soon!
-Jeff
Old Jul 18, 2003 | 02:53 AM
redrotorR1's Avatar
LS6 Convert
Originally posted by HeatTreated
Keep at least 1/4 of a tank when racing ....
Try 3/4 tank. Auto-x has a tendency to slosh the gas around and cause fuel starvation. I've seen it even at 1/2 tank.
Old Jul 21, 2003 | 08:52 PM
tpdrx7's Avatar
Agreed at 3/4
I agree with the 3/4 tank. Otherwise you'll find yourself without fuel on any hard LH turn.
Tomas
SS #142
Old Jul 24, 2003 | 01:25 AM
turbojeff's Avatar
Do it right, do it once
I've experienced fuel starvation at slightly above 1/2 tank. Keep it full if you can. Prevents the fuel from sloshing around.
Jeff
Working on a simple fix for starvation...
Old Jul 24, 2003 | 10:56 AM
maxpesce's Avatar
Ex fd *****
I have NEVER had fuel starvation in my FD even at 1/8 tank at the Streets of Willow Springs and approx 1/4 at Buttonwillow (full track) BUT I only run w/ street tires so this may only be a problem w/ RACE tires that let you corner at over 1g
Old Jul 24, 2003 | 11:24 AM
Rated R1's Avatar
Oji San
Yes definitely run with at least a 1/2 - 3/4 of a tank.
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
