Kenmore Tuning!!
Old Jul 13, 2003 | 03:25 AM
Metallic_rock's Avatar
Ride 'n Style
Thumbs up Kenmore Tuning!!
Check this out... me and a few buddies were screwing around... we didn't like the stock intake... we wanted to do something better. We will be running the tube out in front of the radiator for cold air as soon as we get more tubing.
We were halfway into detailing the engine bay (we = me and IoTus, and my friend Dave) when we decided to do this.
Explanation below...
notice the kenmore symbol on the adapter? Hell, yeah!!! Ok... here's what we did.
We were looking at IoTus's car for tubing that he wouldn't need with his TII swap, so we pulled his intake tube off.... sat and tried to figure out how to install it with a K&N cone filter.
We found the inlet piece for a garbage disposal that I had in my garage... don't ask. We cut slots in the sides near the bottom, pulled the mount piece out of the stock air box. (pain in the ****) If you decide to do this, you will need an air chisel or a jigsaw or something heavy duty. it took us a while. After we got the bracket out, we put it in from the inside, bent the brackets by using a hammer. We just screwed it in like normal. slide the intake tubing over the top, put a hose clamp on it, K&N and go. (BTW, you have to cut off the metal part that hooks onto the SE intake)
Old Jul 13, 2003 | 04:45 AM
RotorMotorDriver's Avatar
Seven Is Coming
Interesting...
~T.J.
Old Jul 13, 2003 | 04:54 AM
eddierotary's Avatar
back with rotaries
pretty cool, did you fell any diference with that setup?
Old Jul 13, 2003 | 05:08 AM
Seven Is Coming
Next time just cut a hole in the hood over the carb and bolt the air cleaner straight o the carb .
~T.J.
Old Jul 13, 2003 | 08:14 AM
Pittdp's Avatar
Thats getto.
Old Jul 13, 2003 | 10:47 AM
1rx7owner's Avatar
Lifes a garden dig it.
Old Jul 13, 2003 | 11:48 AM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by Pittdp
Thats getto.
Leroy Likes it. (and only Leroy)
Old Jul 13, 2003 | 02:13 PM
Pele's Avatar
Right near Malloy
It slices, It DICES! It does a 14 Sec quarter mile! Buy it on your Sears card and get 10% off.
Old Jul 13, 2003 | 10:20 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Does it run, how does it rev?
Old Jul 13, 2003 | 11:02 PM
Its better than no air cleaner.... should just buy a holley setup, and one of those blow thru hats...... would have been easier and probably more hp gain.....
Old Jul 13, 2003 | 11:10 PM
Old Jul 14, 2003 | 10:56 AM
Ride 'n Style
"pretty cool, did you fell any diference with that setup?"
Big Difference!!! My ***-O-METER said it's faster.
"It slices, It DICES! It does a 14 Sec quarter mile! Buy it on your Sears card and get 10% off."
We were thinking of jokingly sending a copy of the pic to Sears and ask for sponsorship....
"Thats getto."
Ok, I used the stock intake from an SE and just fabbed an adapter? Using the garbage disposal adapter just made things easier... didn't have to worry about getting a flanged tube made. The muffler shop wasn't open, so I couldn't get the extension pipe to run it down in front of the radiator for a true cold air intake. As soon as I get that done, I'll post pics of it, as well. I, personally think it is much better than the write-up on mazspeed.com and just about any other "cold air intake" that I've seen. Take a look at some of the new Jeeps, Chevys... see how their intakes are done. I did mine almost the exact same way. It works well, and it doesn't look bad at all.
Old Jul 14, 2003 | 11:34 AM
Rx7carl's Avatar
Airflow is my life
I likey! Nothing wrong at all with it!
Old Jul 14, 2003 | 11:59 AM
Ride 'n Style
Thank you, Carl... looks a little better than your insulated one, I think... (I'm sure yours stays colder, though)
Old Jul 14, 2003 | 02:54 PM
Rx7carl's Avatar
Airflow is my life
LOL, not by much! *cough* getto *cough* A smoother pipe would be better, and the largest radius bends you can make would help efficiency.
Old Jul 14, 2003 | 03:50 PM
Ride 'n Style
Well, we needed the adapter to be able to screw in, so that meant we couldn't weld a pipe onto the top of it, because then we wouldn't be able to use the wing-nut. So, the elbows will be rubber, on the top of the carb, at least. I'll check into getting the muffler shop to just bend me a pipe to make the tube go all the way in front of the radiator instead of just a tube between the two rubber elbows. It will look much better with the pipe, as well.
Any other suggestions?
Old Jul 17, 2003 | 03:15 PM
Ezekiel702's Avatar
Links dont work for me... i wanna see
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
