Water pump won't come off!
Old Jul 12, 2003 | 02:20 PM
Glazedham42's Avatar
Resurrecting Gus
I've got everything off and the water pump should slide off of the four bolts, but it wont. (It's a 12A engine).
It looks like the water pump is rusted to the housing and it's trying to take the whole housing off when I try and pull on it. Have I forgotten to take something off? I have a Haynes manual and I've followed EVERY step exactly.
Any ideas? Any help is greatly appreciated.
Old Jul 12, 2003 | 02:24 PM
Gatorgunner's Avatar
hit it!
Old Jul 12, 2003 | 02:47 PM
hornbm's Avatar
FD > FB > FC
he's not kidding man, a few quick hits with a hammer will break the thing free.
Old Jul 12, 2003 | 03:31 PM
Resurrecting Gus
That worked! Thanks a ton!
Now...
The pump is off, but I'm trying (without much success) to get the remaining bits of gasket off of the housing. Do any of you know a quick way to remove the rest of the gasket??
Thanks!
Old Jul 12, 2003 | 04:16 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
either try sanding it or if u have access to a grinder....grind the housing clean before u put the new gasket on
Old Jul 13, 2003 | 04:53 AM
RotorMotorDriver's Avatar
Seven Is Coming
A can of gasket remover, a putty knife, and some sand paper. Take your time and do it right on all the sealing surfaces, including the housing to block surface. No sense in getting that far in to just let it leak again .
~T.J.
EDIT: FYI, a rubber mallet works just as good as a hammer, and is a little less damaging .
FD7KiD
15
Feb 26, 2021 10:12 PM
rotor_veux
Aug 31, 2015 07:49 PM
FD7KiD
Aug 17, 2015 11:50 PM
