Lowering an FD
Old Jul 3, 2003 | 09:36 AM
HDP's Avatar
HDP
A Fistfull of Dollars!
Lowering an FD
Is there a way to lower an FD and keep the stock springs?
Old Jul 3, 2003 | 09:49 AM
DamonB's Avatar
Yeah, put Konis on. They have adjustable perches.
Old Jul 3, 2003 | 11:48 AM
HDP's Avatar
HDP
Is there a link for them?
Old Jul 3, 2003 | 01:25 PM
cewrx7r1's Avatar
Eye In The Sky
Yes, it is called a GOOGLE search!
Old Jul 3, 2003 | 01:30 PM
tmiked's Avatar
Waiting for the RX-9
You can cut the springs also
(Ignore the Smart-*** !)
Old Jul 3, 2003 | 01:59 PM
HDP's Avatar
HDP
Thanks! I was doing just that
Old Jul 3, 2003 | 03:25 PM
RX-187's Avatar
live fast. die fun.
Going the Rice Route?
Old Jul 3, 2003 | 03:59 PM
HDP's Avatar
HDP
Me? No way... I'm going to look into the Koni Sport.
Old Jul 3, 2003 | 04:58 PM
rynberg's Avatar
Oh, that's good advice...
BTW, what's so smart *** about the google comment. Jesus, you people are #%@ lazy. I mean, it's www.koni.com, how hard is that to figure out?
Also, with the stock springs, you probably can't use the lower perch settings up front with the Koni's or you will rub. BTW, you do know that you can get performance springs that lower your car an inch and only cost a little over 200 bones, less for used ones in the classifieds....
Old Jul 3, 2003 | 05:45 PM
kyle@insight's Avatar
Dont like it? I dont care
why not just lower the car the right way?
Old Jul 4, 2003 | 07:32 PM
tmiked's Avatar
rynberg
I just called you a SA because you sounded sarcastic and someone who doesnt waht to throw $200 for a set of springs probably isnt gonna spend $350 for a set of Koni's.
I'm gonna buy up all the stock springs i can find for $5 each, cut off half a coil and sell them as 'Eyebach' Racing Springs. Nobody would ever know the difference. Hell ! they might work better.
Old Jul 4, 2003 | 10:44 PM
Mahjik's Avatar
Mr. Links
Re: Lowering an FD
Just curious, is there any particular reason you want to keep the stock springs?
Using H&R, Eibach, Racing Beat or some of the other aftermarket springs is a good way to lower the car as well as add better handling.
Old Jul 5, 2003 | 02:19 AM
HDP's Avatar
HDP
Re: Re: Lowering an FD
Well, I have R1 springs, so I thought they were comparable to aftermarket lowered springs.
Old Jul 5, 2003 | 03:53 AM
maxcooper's Avatar
WWFSMD
R1 springs are absolutely identical to other springs from 93. All models have the same springs -- it is basically just the shocks that were different across the model line. The springs were softened ever so slightly in 94, but it was only a few pounds difference and probably not significant.
-Max
Old Jul 5, 2003 | 10:48 AM
DamonB's Avatar
Re: rynberg
...probably isnt gonna spend $350 for a set of Koni's.
If you found a set for $300 buy every single one they have.
Old Jul 6, 2003 | 05:58 PM
cpa7man's Avatar
Racing is life!
-Max
Thanks for that info. I had been curious as to the model and shock and spring rates.
We put H&R springs on a 94 touring, at the same time we installed some shock from an R-1.
Car handles great, rides just as good as stock setup, and is 1-1/2 inches or more lower. Also it took less than 4 hours to do the entire job.
Old Jul 6, 2003 | 09:21 PM
tmiked's Avatar
Solution ?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421939314
iamsisyphus
Sep 27, 2015 01:42 PM
Bill B
Sep 18, 2015 01:36 AM
Ernstudet22
Sep 14, 2015 09:19 PM
