Air Filter Question
Old Jun 28, 2003 | 03:56 PM
Marcel Burkett's Avatar
Question Air Filter Question
How does one know when a filter may be too small for a certain application ?, If you look at my pics in the previous thread you'll see that I am a filter with a red plastic heat shield on it . I removed this and left the filter element exposed , whenever I rev the car (whilst at idle ) one can actually see the filter being sucked in , so I am now wondering what may be happening when I am boosting and the turbo is pulling harder !!.
I s this normal , do you guys get this with those large K&N kilters ??.
Old Jun 29, 2003 | 04:21 PM
Fatty_FC3S's Avatar
Wow, you must be moving alot of air to do that......or....your filter is really restrictive.
Im going to run a 4" inlet K&N (9" long) on my upgraded turbo on my T2. The less restriction the better. Get a bigger filter that flows more air than what you need and you should be fine. Stick with the K&N, they do a good job of filtering, unlike the crap *** Blitz ones that are only good for filtering out small birds. Sometimes you see japanese cars with 2 filters and 2 pipes that merge into one for a single turbo. Most likely the reason that they do this is for more filter area and thus less restriction. The long an the short of it is...you need a bigger filter area.
Old Jun 29, 2003 | 05:19 PM
apexkw's Avatar
in slow, out fast!
um nope my filter doesnt get sucked in on my single setup. i am using a apexi conical filter.
Old Jun 29, 2003 | 06:50 PM
setzep's Avatar
yeah, if it gets sucked in while doing a free rev you have problems.
Queppa
Nov 18, 2024 03:47 AM
The1Sun
Mar 18, 2018 11:08 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rkhanso
Aug 13, 2015 11:40 AM
