99 spec taillights
Old Sep 10, 2001 | 11:03 AM
ejmack1's Avatar
Lawn Ornament
99 spec taillights
anyone have a link to the howto page, i searched but couldn't find it..
Old Sep 10, 2001 | 11:34 AM
Touring FD3S's Avatar
Not sure how many there are out there, but this is the one I used and it worked great.
http://mysite.directlink.net/jott/rx...ts/default.htm
Old Sep 10, 2001 | 11:36 AM
djantlive's Avatar
You can find the instructions at:
http://mysite.directlink.net/jott/rx-7/lights
When you take off the taillight, unscrew 3 screws and take the black platic panel off. Slide the tail light outward parallel to the ground. Give it a few small nudge and the tail light will come off.
It took me about 6 hrs to do, probably 3-4 hrs to do it now since I am more experienced. I love the results! I can do it for anyone who is interested for $65 if you ship it to me in SF. The end product is just like what the picture looks like. Sweet!
Old Sep 10, 2001 | 11:59 AM
ejmack1's Avatar
Lawn Ornament
what do you guys recommend for tools, will a blow dryer work, what type of paint, what size circles, how did you position them, i know the web site says thi but what have you guys done????
Old Sep 10, 2001 | 02:54 PM
I used a heat gun (blow dryer just doesn't cut it in my opinion)exacto knife, glossy black laquer (stuck pretty well), screw driver, regular paper and clear contact paper (easier to line up since it is clear). After I had the pieces apart and the circles were cut (used sizes on the site (75mm turn and 80mm brake), one set w/ contact paper and one set with regular paper), I lined the regular paper up on the inside of the lense and taped them in place, then attached the contact paper to the outside of the lense by lining up the circles. You can basically play around with the alignment until you find something you like. Then I put a few coats on the outside of the lense, removed the contact paper, put the lights back together, and now they look 10x better.
Old Sep 10, 2001 | 03:57 PM
ejmack1's Avatar
Lawn Ornament
what do you mean you put some on the outside of your lense?
Old Sep 10, 2001 | 04:22 PM
By lens I meant the red and yellow inserts you take out and paint on, by outside I meant the smooth side is the side I painted on.
Old Sep 10, 2001 | 05:18 PM
djantlive's Avatar
Yeah, the heat gun works really well and didn't burn any plastic. Any black spray paint (semi gloss or flat) will do. I used scissors to cut the circle but it was a little hard to get perfect edges.
For positioning, I recommend drawing a haircross on each circle to help you line up the brake circles. The turn signal circle sits a little lower than the brake circle. I used 3" turn circle (75mm) and 3.25" (80mm) brake circles.
Have fun with it and make sure to put at least 5 coats of paint and give enough of time (10-20 min) btwn coats.
Old Sep 10, 2001 | 10:24 PM
FDeez's Avatar
If I'm not mistaken, the real J-spec taillights have the circles in the outer (dark) housing instead of the actual colored lenses, right? Don't get me wrong, these DIY mods look great and sure as heck save on $400. Can any with the j-spec ones confirm this info? And has anyone tried painting the insides of the outer housing? Might be a bit tricky to align the circles relavent to the lenses though, eh?
Old Sep 11, 2001 | 01:27 AM
djantlive's Avatar
I don't think you can/should paint the smoked lens cover bc it's a curved shape. It's pretty hard to tape a circle to a curved shape and keep it flush so the paint doesn't bleed. The smoken lens cover also masks any tiny imperfection in the painting processing. Painting the lens cover would make any small imperfection more obvious.
I don't know what the real J-spec light are like opened up. I saw someone had it on the street (maybe it was a conversion job as well) and I was drooling! When I heard that I can do this conversion for less than $50 in parts & tools, I had to have it.
Old Sep 11, 2001 | 02:22 AM
BlackR1's Avatar
Meesto Spakaro
the j-spec tail lights are covered on the inside. it looks like its just a vinyl or small plastic covering over the colored lens. That's the only difference...you cant really tell between the two
Old Sep 12, 2001 | 10:30 AM
ejmack1's Avatar
Lawn Ornament
Hey what if i got someone to make a vinyl covering for it? will it look the same? For the inside lens of course.....
Old Sep 14, 2001 | 10:18 AM
I did my tail lights Wednsday night. They cane out perfect. Did just what they said in the link and now I have 99' lookalike tail lights. This is an awsome thread. I wanted the 99' lights but couldn't afford them right now because of school. This was relatively easy to do. The tail lights came apart easier than I expected. The only difficult part was making sure both tail lights were exactly the same. I'm shikled titless right now . Thanks guys!
