Hell Yeah!!
Old Jun 28, 2003 | 01:02 AM
setzep's Avatar
Talking Hell Yeah!!
My car runs!!!
I fired it up for the first time tonight after working on this project for 2.5 years. Started on the first turn of the key. Now it's time to get a timing light so I can see if what the haltech says it's at is what it's really at.
Not going to sleep good tonight!
Can't wait to play with it tomorrow
Old Jun 28, 2003 | 01:10 AM
diabolical1's Avatar
congratulations!
Old Jun 28, 2003 | 02:36 AM
rx7passion's Avatar
about ****** time man...
Old Jun 28, 2003 | 06:41 AM
timmya2's Avatar
damn nice dude
Old Jun 28, 2003 | 06:51 AM
jimmyrose99's Avatar
well done, 2.5 years... ouch
Old Jun 28, 2003 | 09:57 AM
setzep's Avatar
Just went out to the garage and took a couple quick pics. I still have some work to do like make heat shield for turbo, relocate air filter (so it isn't sucking hot rad air), get some good hose clamps for the IC tubing and a couple small things I wanta change. But tell me what you think, positive or negative.
Old Jun 28, 2003 | 10:04 AM
setzep's Avatar
Here is the remote mount oil filter. The filter holds a quart of oil. Also have a gauge right on the filter head so you can see what pressure you're at while dinking around under the hood. The oil cooler is under the drivers side headlight (no I didn't shove the stock rectange one in there ). It's about 10x10 inches and has a 8" fan mounted to it with a shroud.
Old Jun 28, 2003 | 10:17 AM
setzep's Avatar
And here is the business end of things You can see why I need a heat shield between the turbo and lower intake manifold.
Old Jun 28, 2003 | 10:31 AM
holeee ssshhhh ...
which snail are you running? (if you don't mind my asking ... if it's a secret, i understand)
all in all ... i give you two thumbs up for the presentation and install!
i especially like the oil filter assembly with the gauge ... REALLY nice touch, dude! yeah, i agree about finding insulation from the turbo's heat. building a shroud is a must, but also, wrapping the turbine should also increase efficiency, right (at least in theory)? and, yes, the air filter needs to be moved away, but i guess finding an ideal spot may pose a small challenge, with a nose full of intercooler and all ...
great job! after 2.5 years, you deserve it ... enjoy!
Old Jun 28, 2003 | 11:08 AM
setzep's Avatar
Thanks, it's a Mitsu TD07 turbo with a 25G compressor and a 17cm turbine housing. I guess it's like the T-78 but with a different compressor (T-78's is better).
Well off to get a timing light so I can zero the timing and try to get it to idle a little better.
Thanks again for the kind words!
-Cam
Old Jun 28, 2003 | 11:40 AM
inittab's Avatar
I read your email
OMG! That is awesome! Very very nice work!
Old Jun 28, 2003 | 12:16 PM
Mschafe's Avatar
Where did my 7 go?
Hmm.... having an '83 myself that I WILL turbo someday, care to give me a spin when its all up an running? Ya know, just to see what I can expect. hehe.
Matt
Old Jun 28, 2003 | 02:04 PM
ioTus's Avatar
'84 5-letter
Looks OK, i donno, i think you should have cleaned the engine bay up a bit, looks kind of messy.
(Just kidding of course). That is a truly beautiful thing, man.
And you know, from all the posts i'ver seen about you'r car, i've ONLY seen engine shots. Post some pics of the whole thing!!!
Old Jun 28, 2003 | 02:15 PM
gonzz's Avatar
where did you get the engine? Also how much hp will it make?
Old Jun 28, 2003 | 03:08 PM
1984special's Avatar
So little time and money
That's a very beautiful and clean install. Congrats on the excellent work. Hope you get to tie up all the lose ends... (turbo wrap, heatshield etc)
=) happy rotoring
Old Jun 28, 2003 | 04:51 PM
setzep's Avatar
inittab- Thanks for the kind words!
Mschafe- We'll see
iotus-I'm more about the go than the show. But you're right, I still have a few loose ends to tie up.
haha, you're right, I can't remember posting any pic's of the whole car in a LONG time. Maybe I should do that. It looks 100% stock becides it sits a little lower and has a 3" flat black muffler out back (no bling for me). But it sure doesn't sound stock
gonzz- Got it from fc3s.org If you are looking for a j-spec get it from there! Dave there is a great guy to deal with and will make SURE you get a good engine. Looking to make 350rwhp at 15psi.
1984 special- Thanks, going to hit the steel yards monday to try to source out some thin stainless.
I just did some no load tuning and I got it to idle MUCH smoother, had to take out a lot of fuel. When it ran it last night it was smoking like a **** even at idle,when I took out some fuel the smoke went away the rpms went up and it stoped stumbling. Now I need to get my hands on a wideband o2 meter so I can start the process of load tuning.
On a side note to anyone that wants to do this to their FB/SA. I say do it if you have #1 the money to spend and #2 if you have the patience. There were some times where I asked myself WTF I was thinking but now that I'm close to the end it's all worth it!
Old Jun 28, 2003 | 05:11 PM
Congrats on gettin' her runnin'!!!!
MORE PICS OF THE WHOLE CAR and where you mounted stuff inside, hehe
Old Jun 28, 2003 | 05:41 PM
I am all most freakin out over here, being that I have nearly the same setup...but not runnin. Can you come over and finish mine? I will give you and install a complete J.O Rack Kit on your car while you finish mine.
Whatcha think, deal? LOL.
Old Jun 28, 2003 | 07:05 PM
fatboy7's Avatar
Got Boost?
Nice job!!! Good luck on the tunning...
I'm back from vacation now, so back to work on my own turbo beast....
Old Jun 28, 2003 | 07:33 PM
LTProject's Avatar
setzep, congrats on the completion. Im drinkin a beer for ya right now. Theres no need to be sleepin either, you can do that later. Get that thing tuned and go blow somebodys doors off.
Old Jun 28, 2003 | 07:37 PM
SetzUp, Did you remove the D shaped exhaust sleeves or did you just leave it stock?
Old Jun 28, 2003 | 08:24 PM
setzep's Avatar
79+80+84- hope tomorrow is nice so I can put the hood back on and wash it, then I'll take pic's of the exterior. The inside is half -se interior and half 83. Seats, carpet, door skins are gray -se and teh dash and headliner is 83 black.
J Oliver- hmm... free rack and pinion for getting your car running, sounds tempting! Oh wait you are way up in BFE, nevermind
Still have the D sleeves in. We'll see what they can get me for power. I didn't want to take the engine apart just to replace the sleeves so they stayed in. I'm glad I did to because this engine seems to be pretty good, at idle it pulls 20in of mercury.
fatboy7- thanks, I'm going to need all the luck I can get while tuning this sucker. Next on the purchace list is a WBo2 meter. I think thats the last of the big $ items (thank god!)
LTProject- haha, went to bed at 3 last night because of this car. Hope to get a WBo2 soon so I can do some real tuning then it's time to take out some hot heads
Old Jun 28, 2003 | 09:04 PM
FB II's Avatar
holy forkin hell; that is amazing. one day........
Old Jun 28, 2003 | 09:31 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
looks good man,
How much was you manifold, is your turbo internally or externally gated?
im planning on going with the HKS manifold, I was told that it is very close to the idler arm so im going to wrap it and make a metal heat sheild for the idler arm.
Old Jun 28, 2003 | 10:14 PM
setzep's Avatar
thanks guys, I made the manifold from scratch. I didn't want a cast one so I had to make one If you take a look at the 3rd pic you can see the external WG hanging out under the DP.
