Microtech Official LT-8 Dumb ? Thread (installation)
Old Jun 25, 2003 | 09:56 PM
HIMNI Racing's Avatar
Rick James
I don't even have my EMS yet and I have alot of dumb ?'s. Anyone else that has dumb ?'s can also ask them here but,........It has to be dumb
After looking at the wireing diagram on brandon's site...........here---->http://www.br7racing.com/downloads/LT8-FC-Diag.jpg
I want to make sure I got it all right.
#1 A wire goes from #86 on the fuel pump relay to the pink wire on the L coil & then to both TAN wires on the #1 T coil? Is that right? Is that 12v power going to or from the coil?
#2 How does my MSD 6a wire into the L coil now?
#3Where does the GREY wire on the #2 T coil go?
#4 It says the yellow is tach out........out to where, the gauge?
#5 Is fused 12 volts always going to the lt-8 & the injectors, even when the car is off?
#6 On the CAS, Both the white wire & the white w/the black stripe wire go to ground?
I don't have the harness/female plug for the air temp sensor. Does it matter what prong the two wires go to? ( have them backwards) Same for the water temp.......
That's it.........for now.
Old Jun 25, 2003 | 10:38 PM
No7Yet's Avatar
Calm down.
Installation is cake.
Don't worry about it until you get the thing in your hands. I'll all become clear then.
Brandon
BR7 Racing
Old Jun 25, 2003 | 10:43 PM
luiml73's Avatar
Rotary Powered Boobies
I have a question. where's my $50
Old Jun 25, 2003 | 10:45 PM
No7Yet's Avatar
Hahaha we're mailing them all out on Friday - we've been busy writing checks and fighting with QuickBooks!
Brandon
BR7 Racing
Old Jun 25, 2003 | 10:53 PM
Rick James
hay hay!!! That wasn't a "dumb ? I'm installing a EMS I don't have yet
Old Jun 26, 2003 | 06:38 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Official LT-8 Dumb ? Thread (installation)
That is a very strange wiring diagram. I would've thought the fuel pump would have its own relay, fed from the battery and switched by the ECU, and there'd be another ignition switched relay that feeds 12V to the injectors are coils. This is how the factory does it, and how other aftermarket systems seem to be done also.
Yep, there's a wire in the factory loom that runs from the trailing coil to the tacho.
They're just thermistors, so it doesn't matter.
Old Jun 26, 2003 | 08:52 PM
No7Yet's Avatar
Re: Re: Official LT-8 Dumb ? Thread (installation)
That is how it's done. The wiring diagram doesn't exactly match the ends of the wiring harness; it doesn't show the branches within it.
That's why I said to not worry about it until then - it's pretty intuitive once you're holding it and looking at the pre-labelled harness.
Brandon
BR7 Racing
Old Jul 1, 2003 | 11:14 AM
Josepi's Avatar
Despise Enmity
Re: Re: Re: Official LT-8 Dumb ? Thread (installation)
Brandon
BR7 Racing
Agreed. I was thrown by the diagram...but it made much more sense after staring at the labelled harness.
Old Jul 1, 2003 | 11:20 AM
Josepi's Avatar
Despise Enmity
x2
Claudio RX-7
Haltech Forum
Apr 23, 2019 02:50 PM
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
