Microtech Laptop Crashing?
Old Jun 25, 2003 | 09:10 PM
Turbo Timmy's Avatar
Professional Lurker
Laptop Crashing?
I've got Beta V1.1 of the software running on a XP laptop with a Keyspan Serial adapter.
Tonight while trying to do some logs something strange happened. I started the log at the tree as normal but when I got to the finish line to stop logging I looked and saw lost connection to the ECU but the logger was still logging. When I tried to stop logging it wouldn't let me click stop because two dialog boxes "no connection to ecu" and "logger is alread running" kept popping up. I finally had to close and reopen the program to get a good connection. My cables were secure (screwed together) so I know there wasn't a loose plug.
Does anyone have any clue what could have caused this?
Old Jun 29, 2003 | 03:27 PM
Silver88GXL's Avatar
Same thing on windoze 2000 pro. That happens to me but not too terribly frequent. I more often than not get a lost connection to the ecu but it allows me to stay in the program. Hopefully it is just a beta bug and will be fixed soon.
Old Jun 29, 2003 | 04:17 PM
REFLUX's Avatar
www.v8less.com
so what happens when you're driving/tuning/using the laptop & it crashes???
does the car shut down? you lose all your unsaved info?
(as you can tell I'm a complete n00b to EMS')
Old Jun 30, 2003 | 07:09 AM
Josepi's Avatar
Despise Enmity
It's happened to me even while making changes...
Car keeps running, and my most recent changes stayed. Any idea on when the software will move past a beta version?
Old Jun 30, 2003 | 08:27 PM
10sec rx7's Avatar
They are on the second version already which is what you guys have,
i have been using the software since day one and it has not crashed on my once yet,
im using windows 2000 with SP3 and XP with SP2 on it, and also win 98.
Check your SP's
Dale
Old Jul 1, 2003 | 11:23 AM
Piranha's Avatar
what 7
It crashes on me all the time, and I am using 98. On 2 different laptops. But it works.
Old Jul 1, 2003 | 08:25 PM
Check your SP's
Dale
Ok, I am a macintosh man and know diddly squat about windoze things. It was a painful decsition to get a windoze laptop. What is a SP? and how do I check it?
Thanks
Carl
Old Jul 1, 2003 | 08:49 PM
Crusader_9x's Avatar
its called a service pack. u get it off of windows update. it should be an option on the start menu. but it is highly recomended that u have dsl or cable. cuz these sp's are kinda big. basically it is just an update for windows.
Old Jul 1, 2003 | 09:27 PM
Ah, ok. I am not used to having to update on my own. My apple does that automatically. I guess I will check and update the ole' laptop.
Thanks Riley
Old Jul 2, 2003 | 06:53 AM
SaabGuy's Avatar
Mine crashed on me once when I was saving a map. I had to reboot and then save the map again.
Also sometimes when I save a map while the car is running, the engine will stall. Most often does not stall though.
Old Jul 2, 2003 | 07:35 AM
Hmm, never had to reboot the laptop, just the program. Also, never had it stall, but it really sucks trying to get back to the main screen to reconnect and steer at the same time. I think Brandon is indirectly trying to kill me.
But, I am now running 2000Pro with service pack 4!! (all together now) Wwooooooooooooo!! Just in case you missed it, that was .... 4. You all look out now. I am rollin now.
I really need more sleep.
Old Jul 3, 2003 | 04:32 PM
how how long of a dl was that for all 4 service packs lol? but does it really make a difference in the softwares performance?
Old Jul 4, 2003 | 03:07 PM
Apparently I was already running service pack 3 so it was an update to 4. The download was quick, but the install was horrifically long.
Haven't had a chance to play with the car yet so I am not sure about the performace yet.
befarrer
15
May 19, 2022 10:44 PM
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
Andrew7dg
Aug 6, 2017 01:41 PM
