stationaries
Old Jun 24, 2003 | 04:45 AM
stationaries
hi! everybody
iam rebuilding my 13b n/a with 12a end plates. now there is a difference between 12a and 13b stationary.the 12a stationary tooth are shorter compare to the 13b.now it is ok to use the 12a instead of the 13b and the question is made because i see that the tooth from the 13b when i start to put the engine toguether are very close to the rotor bearing and as far i understand they expand under heat.so i need an advise on which one to use.thank you
Old Jun 24, 2003 | 10:33 AM
rxtasy3's Avatar
Ur building a 13b so use the 13b statioinary gears.
Old Jun 24, 2003 | 03:13 PM
Jeff20B's Avatar
Lapping = Fapping
There's a 5mm difference.
Old Jun 24, 2003 | 03:37 PM
Cody's Avatar
SKELETOR!
Just cut a few teeth off, and you'll be fine.
Old Jun 24, 2003 | 04:48 PM
thank you
Old Jun 25, 2003 | 01:38 AM
Jeff20B's Avatar
Lapping = Fapping
Just take it to a bench grinder. It just sits there, stationarilly, so it's not like it'll be out of balance when you grind the gear teeth down. I'm kidding. Don't grind your gear. Get the correct one for the width of rotors you're using.
Old Jun 25, 2003 | 03:58 AM
i will be using the ones from a gsl-se
Old Jun 25, 2003 | 01:42 PM
Jeff20B's Avatar
Lapping = Fapping
That will work great.
Microtech
30
Apr 23, 2016 06:37 PM
rx7tt95
20B Forum
Mar 9, 2003 07:01 PM
scathcart
Mar 27, 2002 04:55 PM
