would a rb header fit
Old Jun 23, 2003 | 04:21 PM
85gsl2ndtimearound's Avatar
Went to the junk yard today. Only one rx-7 in the place. Anyways took a header off the 83 will it work on my 85gsl? What do i run after the header? Also how hard is it to install DLIDFIS And wher do i get the extra ignitors. Thanks for your help much abliged.
Old Jun 23, 2003 | 04:26 PM
851stgen12a's Avatar
Off riding sportbikes!
If its a 12a the header will fit.
Old Jun 23, 2003 | 04:30 PM
Metallic_rock's Avatar
Ride 'n Style
so, did you take the exhaust manifold off an 83, or did you score and find an actual header?
Old Jun 23, 2003 | 04:45 PM
no i took it off. had to jack the car up though. whay else do i need as far as exaust. it was a 12a. i paid 21 bucks for the 2 coils a hose and the header. did i get riped off?
Old Jun 23, 2003 | 09:18 PM
poweRX-7's Avatar
is it a header? or just the exhaust manifold? go to racingbeat.com, and find a header... if it looks like that, you scored!
Old Jun 24, 2003 | 01:11 AM
Rotor13B's Avatar
Wassup!!
go back to that junkyard and grab the ignitors of the distributor.
Old Jun 24, 2003 | 02:02 AM
Where are those located the ignitors that is?
how do i get them off?
Old Jun 24, 2003 | 05:06 PM
anyone?
Old Jun 24, 2003 | 05:38 PM
wwilliam54's Avatar
it WILL run
2 boxes on the distributor
Old Jun 24, 2003 | 06:09 PM
rhinor61's Avatar
The ignitors on all '81-85 are on the side of the distributor (2) which are black. They are the size of a book of matches, attached with 2 phillips screws each and plug into the side.
Easier to use a 10mm socket and pull the distributor out housing and remove them.
BLK 93
11
Sep 9, 2015 10:56 AM
