gt35/40 shopping list....please take a look?
Old Jun 21, 2003 | 11:20 PM
fd3virgin's Avatar
my sister is coming over from australia....was going to try to get a gt35/40 kit from down under for cheap...in addition to the kit what will i need???
fuel pressure regulator?
bov? or is it included in the kit?
front mount? ( have a greddy smic)
850 cc primaries? ( have 1300 cc injectors)
better pump? ( have a cosmo pump)
any suggestions are apprecitated.... how hard is it to drop the fmic and single in??? i have swapped out the twins before by myself w/o much problem... does the kit fit easily or does it need a little ghetto rigging? and one last question who wants to help me drop that baby in when i get it thanks kevin
Old Jun 22, 2003 | 08:44 AM
93rotorhead's Avatar
I put my own front mount in and put a new radiator in at the sametime. After it was over with I had to take the A/C off and put it back on and make about 20 trips to the local hardware store because I pulled my radiator forward because my fmic had to go were it used to be.
The fmic conversion wasnt a weekend job for me but it was worth it in the end. I used a koyo radiator from radiator.com, 330.00 and as far as the single conversion goes it looks to me like you have everything.
Channon Lee
Old Jun 22, 2003 | 09:07 PM
fd3virgin's Avatar
Old Jun 23, 2003 | 07:54 PM
ZoomZoom's Avatar
SEMI-PRO
Your 550 primaries are fine, upgrade secondaries to at least 1300cc but better 1600cc with rail. 1:1 rate fuel pressure regulator. Front mount is good but everything including the fuel system is dependant on your needs. What boost you planning to run? How much power you trying to make? Do you have 1/4 mile goals? How strong is your motor? Miles? What about clutch?. That street strip wont last long unless you run 10 psi. You gotta upgrade stock components. If your power goals are high your going to need an upgraded Diff and axle shafts. Stock ignition is good for now but high boost 17+ you will need to upgrade that as well.
Old Jun 23, 2003 | 11:35 PM
93BlackFD's Avatar
built my own engine
how much cheaper are they down there?
Old Jun 24, 2003 | 07:51 AM
es's Avatar
es
I'd be weary of that pump. If you do use it make sure to install a pressure gauge so you can see if it's falling off.
Old Jun 24, 2003 | 07:53 AM
fd3virgin's Avatar
might be like 2g's for the whole kit....
Old Jun 25, 2003 | 12:57 PM
IRPerformance's Avatar
Sponsor
I've run 20 psi on a cosmo pump. I wouldn't suggest running it for more than that though. I plan to go with a dual pump setup soon.
Old Jun 26, 2003 | 06:44 PM
ZoomZoom's Avatar
SEMI-PRO
Cosmo pump is used by alot of us with the GT3540 and no problems with pump keeping up with up to 450+ rwhp
Old Jun 27, 2003 | 01:53 AM
Garrett's Avatar
Will a high flow nippon denso pump (the one RX7store sells) work effectively for GT3540s fuel needs. Under what boost does that one crash.
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
