electrical/alternator problems...
Old Jun 12, 2003 | 01:45 PM
treceb's Avatar
i recently installed a rebuilt 13B engine on my GSLSE and went with a carb. did everything as per gruntled.com's info. but ever since i got the car running my alternator heats up as much if not more than the radiator.
the battery is a optima red top(its actually orange, but i asked for a red top and the numbers match). when the car is running it looks as if the alt is not charging properly. the volt meter lingers just above 12V. When hooked up to a battery tester, the battery is on the low side and the alt just above where it should be charging around 13 to 13.5V. when the tester is hooked up to the alt it reads around 14.5 to 15V.
i did swithch batteries and the alt seemed to charge it better, but it still got very hot.
i also ran the car off the alt(no bat) and it ran smoother and noticeably stronger than when the battery is connected.
i have a hard time starting the car and the battery tends to drain if its sitting for over a day.
does anyone have any idea as to where i should start looking into?
thanks
Old Jun 12, 2003 | 02:07 PM
pillage6's Avatar
Try a ground from the negative battery terminal to the alternator bracket, can't hurt.
Old Jun 26, 2003 | 11:19 PM
Newbie
That's so close to my problem. I'm gonna post about it. You guys gotta help me. ))))
Old Jun 27, 2003 | 02:11 AM
13B4port's Avatar
Will Work for Beer
the alt needs power to make power. make sure thepower wire isn't grouned out near the alt. it could be grouned causing the battary to loose charge and the alt to get the power from it being grounded.
if that doesn't help. get a new alt. sounds like that one might have a one of the carbon links for the coils busted or something like that. you can take you're alt to the local auto shop and get a rebuilt one for lik $100 then get a core charge back of $25. making you're bill like $75 or so.
Old Jun 27, 2003 | 02:22 AM
O 16581 72452 5's Avatar
The infamous number guy!
My car seems to never be getting a good charge according to my voltometer - 11volts usually, sometimes it'll go up to 13 but VERY rarely, the charge just kind of lingers from 11 volts to 12... but the battery never goes dead from sitting, even if i listen to the cd player (i have a small amp as well) for about an hour or so while working on my car...
eriksseven
Rotary Car Performance
13
Sep 22, 2005 10:00 PM
20Bforme
Sep 16, 2005 01:14 PM
93Efini
Sep 14, 2005 01:44 PM
Terrh
Time Slips and Dyno
Aug 12, 2005 10:52 PM
SoulPyr0
Apr 23, 2002 09:52 PM
