Microtech T_INJ map and why is my car losing lots og power above 7k?
OK well first I want to say that the stock tachometer really sux on my car and most rx7s.
When it says 7000 the ecu says its at like 6600, so at 7500 the engine is at about 7100.
At this "7500/7100" rpm, my car loses a ton of power. its not like power drop off, more like something is just really wierd. The only ecu related option I can see is thie T_inj map (Screen 27).
I can see on my last dyno that at 6500 actual engine rpms my a/f was 11.5:1, and then at 6650 actual rpms my a/f was 11:1, so it got rich in a hurry.
Now I realize that this all could be my tuning on the 6500, 7000, 8000, 3200000 load map, but lets just view the T_INJ for now.
Please look at this attached file.
I lowered the T_INJ setting at 7000 down one notch. So as it stands the setting is set to ~250 for 7000 rpms down from about ~280. This one adjustment seems to improve the cars power after 7000 rpm.
I did an A:B test on this setting. So far this test is just under stipulation to this point as I really dont know what a/fs are comming out of the pipe.
Before the car would sometimes hit a wall-like restriction. At first I thought it might be the eshaft flexing and the rotor hitting the housing or something but now I have my doughts for that. Yesterday at one point it felt like fuel/spark cut at 7100 rpms.
After this setting change the engine seemed to rev much better to 7500. I think I am going to leave this setting change, as long as the big boys in australia dont mind!
What are your injection times looking like up there? Really the only thing I can see that would cause a BIG problem would be if you were plain running out of time for the injectors to fire.
However I did have a problem with the same setting at the 4000rpm mark, I had a hessitation related to that there.
Daniel
Daniel
Interesting.
My injection times are around the 6.5 to 7ms mark. Thats like 75-80% duty cycle.
Can you perhaps post a before (if different than my attachment) and after of the setting you changed?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
