best engine degreaser?
Old Jun 6, 2003 | 09:00 AM
FB II's Avatar
alright you clean engine guys, hahaha what's the best/safest way for me to clean mycarbeurator before i put it back on? i know there's "carb cleaner" but that **** makes me think i'm gonna wear out the gaskets possibly. should i use a good engine degreaser? i'd like to spray my block down too.
Old Jun 6, 2003 | 09:21 AM
BrewerBob's Avatar
I luv sheep&dead hookers
Why is your carb off if youaren't replacing the gaskets anyway?
For the block, I used the self wask car wash and the 1,500 psi presure sprayer. Couldn't get teh nooks and crannies but where I could there isn't a spot of grease!!
Old Jun 6, 2003 | 09:49 AM
FB II's Avatar
lol, well i'm not rebuilding the carb. i got another one off a running rx7. i tried rebuilding my old one and i failed somehow. so i'm just taking the easier route. when i get it running again i might take the car down the the self wash thing too and try that. they have an engine cleaning solution you can choose. woot!
Old Jun 6, 2003 | 02:53 PM
joelwahid's Avatar
the best degreaser i have seen is this stuff called DESTROYER. i dont know where you can get it, my friend that works at a boat repair place had some and it was bad ***.
Old Jun 6, 2003 | 11:21 PM
anthrax's Avatar
Heck Yes!
Castrol (I think) Makes a product called supper clean. It seems to work well as a multi purpos cleaner. It degreases and removes grime in gerneral.
Old Jun 7, 2003 | 03:52 AM
RotorMotorDriver's Avatar
Seven Is Coming
Yeah, Ive heard good things about the Castrol stuff in the purple bottle, but it says to use caution around aluminum, so I didnt use it due to my aluminum rotor housings. Ive used Oil Eater and just any old generic engine degresers though. Theyre cheap and you can get more for your money. I get the ones that you spray on while the engine is "warm", they seem to be the best for me so far. The grease is runny and oozy when hot, so the cleaner works well.
~T.J.
Old Jun 7, 2003 | 08:25 AM
spoolin's Avatar
for the best kept secret... go to the dollar store and buy some oven cleaner--spray it on and let it sit for a minute or two. works like a champ. didn't believe it til i saw it in action on my transmission while i had it out. recently did it on my GSL-SE that i bought.....i can now see that the strut towers are the same color as the outside
Old Jun 7, 2003 | 10:00 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Warning on Castrol degreaser- My friend and I used it on several old tractors and it totally discolored and streaked the paint..Granted the paint is not clearcoated like an auto but I think the engine bay for most autos is NOT as protected as the exterior skin..You may want check spot first and see if it will damage automotive paint... We went back to using Easy-Off oven cleaner.
Old Jun 7, 2003 | 10:55 AM
bliffle's Avatar
So what's wrong with good ol' Gunk?
F
Old Jun 7, 2003 | 11:21 AM
RacerX7fb's Avatar
paradox
Chemtool engine degreaser and Simple Green both does it!
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
