anybody have 70K miles or more on there stock engine
Old Sep 5, 2001 | 05:10 PM
martin240's Avatar
if so, how many?
Old Sep 5, 2001 | 05:28 PM
bploz RX7's Avatar
74,000 and going strong... knock on wood
Old Sep 5, 2001 | 06:22 PM
Foz'sRX-7's Avatar
Just finished a rebuild at 114,000. Everybody says they can't believe I took it that far without a rebuild. Lucky I guess.
Just goes to show you that it can be done.
Old Sep 5, 2001 | 07:34 PM
BlackR1's Avatar
Meesto Spakaro
73,000 and running great!
Old Sep 5, 2001 | 10:01 PM
Z Zoom's Avatar
87k, no problems yet. Still working on reliability mods.
Old Sep 5, 2001 | 10:55 PM
Storm Knight's Avatar
Prometheus Unbound
Got mine to 115k before the water seals crapped out on me. The record in the club here is held by a guy who had 140+k before his son totaled it...
Old Sep 6, 2001 | 12:16 AM
t-rex7's Avatar
86 and going strong. only problems i've had have been a loose battery cable and the boost sensor hose popped off. total cost of repairs $0.
Old Sep 6, 2001 | 03:59 PM
slilversurfer1973's Avatar
still going and going
117,000 miles on my 93 r1, still going pretty good, just a couple of little things, but all and all good shape.
Old Sep 6, 2001 | 04:40 PM
alwan16's Avatar
see sig
Old Sep 7, 2001 | 10:22 AM
DamonB's Avatar
83,000 miles and making 210hp to the rear wheels with the stock main cat and a downpipe. Sees 8,000 rpm regularly at autox events.
Old Sep 9, 2001 | 01:52 AM
bluesaint's Avatar
91k and still going =)
Old Sep 27, 2001 | 02:47 PM
Wink
117 on original motor and turbos. still running strong.
Old Sep 27, 2001 | 03:05 PM
mmaragos's Avatar
85K and going strong. On jack stands now for more upgrades, but will be back on the road again soon.
Old Sep 27, 2001 | 03:37 PM
Ninjak's Avatar
85k and still on stock turbos running STRONG!!!
Huy
93 R1
Old Oct 9, 2001 | 02:16 PM
R1 POWR's Avatar
89k and goin' strong.
all STOCK until 84k, then it got a cat-back
89k now & i'm finally putting on the DP & efini y-pipe
Old Oct 9, 2001 | 04:01 PM
I am looking at a 1993 that has 106K on the original engine and turbos...
Patrick
Old Oct 10, 2001 | 07:29 AM
bbr1's Avatar
Originally posted by §ilverRx7
76k and pullin' like a son of a b!
Ditto! Completely original drivetrain except for clutch......
Old Oct 10, 2001 | 08:00 AM
Cliff Hiatt's Avatar
71,000+ miles, original motor & turbos. 10-8-10 boost pattern, a little more in cooler weather. 16-18 lbs. vacuum (depends on AC). Downpipe, hose job, home-made cold air duct for stock air box and metal intake manifold gaskets. Pettit AST on the way, stock one finally started leaking (in, not out!).
Old Oct 12, 2001 | 11:02 AM
maxpesce's Avatar
Ex fd *****
103k+ when a water seal blew - started loosing bost @ compression @ around 90k miles - it is my daily driver
Old Oct 12, 2001 | 04:56 PM
77k miles, good boost. very small oir drip somewhere. haven't tried to locate it. No reliability mods yet.
Petros
Old Dec 26, 2001 | 11:49 PM
FD Seeker's Avatar
Rotary Optimist
Talking Almost a record?
125K on original engine, no rebuild - completely stock. Compressoin is even at 110psi and great boost. I just bought it from a very responsible owner (one only).
Original radiator just popped, so I'm replacing it with a Fluidyne.
Just replaced the primary fuel injectors (they were leaking fuel on the engine!).
Because we were in there:
-Replaced the pulsation damper
-Did the silicon vacuum hose job
Need to:
-Replace a motor mount
-Install a new oil pan gasket
-Replace a rear bushing
-Replace the original shocks
Old Dec 27, 2001 | 12:02 AM
bploz RX7's Avatar
74k on a daily driver
Old Dec 27, 2001 | 12:13 AM
Nameless's Avatar
118k here.
Old Dec 27, 2001 | 12:37 AM
Bacon's Avatar
IRS 4 Life
92k b4 water seal let go
