Power FC base modifications map please
Old Jun 2, 2003 | 02:57 PM
YayeR's Avatar
Smile base modifications map please
could someone please direct me toward or provide me with a fuel map and whatever else i might need to change with my Power FC for the following mods: downpipe, hi-flow cat, catback, intake. I would have thought that with these mods benig so common these maps would be easier to find, but everywhere i look i find broken links or maps that don't fit what i need. thanks in advance.
-neeraj
Old Jun 2, 2003 | 07:55 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
The latest PFC version 5.08 is already setup for what you have.
Old Jun 3, 2003 | 03:55 PM
YayeR's Avatar
yes thank you, i'll check to see what version mine is in a few minutes.
Old Jun 3, 2003 | 05:19 PM
YayeR's Avatar
yes i have the 5.08, so this means i'm fine then?
Old Jun 3, 2003 | 09:34 PM
RX7 RAGE's Avatar
Top Answer: 1
yep, you're fine. How much boost do you plan on running?
Old Jun 4, 2003 | 04:32 PM
YayeR's Avatar
whatever's safe, i don't have a boost controller =\
Old Jun 4, 2003 | 07:41 PM
RX7 RAGE's Avatar
Top Answer: 1
the commander can control boost...keep it at 10 psi since u have a stock ic still. read the manual on how to control boost.
Old Jun 5, 2003 | 02:10 AM
cover8's Avatar
the base maps do come for fuel programmed t 16psi right? (in case of spikes or creep?)
Old Nov 20, 2003 | 03:44 AM
fd3typer2's Avatar
Hi, would that mean for Yayer's setup, if he adds a big IC and ups boost he can stick with the base map?
Just that I am in a similar situation.
I have Intake, DP, mid pipe so far. And have so far seen that the PFC will be ok with its base map at 10psi.
It looks like I should get my FMIC before raising boost, but I wanted to know if I will have to modify the map for this?
Or do I have to get a Datalogit and wideband at the same time as adding the IC?
Thanks
Trevor
Old Nov 20, 2003 | 04:16 PM
93 R1's Avatar
I have intake, FMIC, DP, High flow cat, Catback And my car was DANGEROUSLY LEAN on the top end, at only 12 psi.
Be very careful running the base maps. I was told that they were plenty safe and tuned very rich but my car was seeing 12.5-12.8 afr. Luckily I got it tuned before any damage was done.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
danielbradley2
11
Sep 28, 2015 10:44 PM
befarrer
Sep 22, 2015 09:33 AM
Mps_hell
Sep 19, 2015 10:02 PM
