Microtech Went dyno tuning again...
Old May 31, 2003 | 05:33 PM
SaabGuy's Avatar
In all the microtech has been performing to the highest of standards. I am disapointed in the car though.
Today the best pull was 282rwhp (SAE) at 10 psi. Last month I got 300.8 at 13 psi. Today I could not raise the bosot higher than 10psi at redline with my boost controler. It was like pressure loss or really bad air today. My worst pull of the day was 265rwhp with the hood of the car closed; time to open up the fender!! A/F ratios were right on target even after a little home brew tuning from last months tuning.
Maybe I should be happy with these pulls after all, my engine has 153k miles on it. The stock clutch has at least 50k miles on it. The dyno tuner said that today was a really bad day to test peak hp for any car. its been really humid and nasty out for the past 10 days (at least 10).
Old May 31, 2003 | 05:34 PM
SaabGuy's Avatar
sig
Link to last months dyno:
https://www.rx7club.com/forum/showth...5&pagenumber=1
Old May 31, 2003 | 11:35 PM
bl|nk's Avatar
Fok mi
still good numbers nothing to be unhappy with.
did your a/f get smoothed out a bit or were you just doing some power pulls on the dyno?
Old Jun 1, 2003 | 02:08 PM
SaabGuy's Avatar
I basically returned to the dyno because of a few problems which had been resolved. I was going to do some cool power runs but I could not raise my boost past about 10 psi this time around.
Old Jun 1, 2003 | 10:59 PM
bl|nk's Avatar
Fok mi
What boost controller are you running?
Old Jun 2, 2003 | 07:30 AM
SaabGuy's Avatar
I rigged one up to work off the microtech ecu. The controler allows air to pass through to the w/g actuator at a specified pressure programmed in the ecu.
Old Jun 7, 2003 | 12:26 AM
SaabGuy's Avatar
Looks like my clutch has finally let it be known.
It has begun to slip. tonight in 3rd gear from 5k to 7k. really nasty. it only did this once but I suspect this is the reason for the power loss on these pulls.
Seems my car is getting slower every few days. Must be clutch.
Old Jun 26, 2003 | 04:49 PM
Poindexter10thae's Avatar
AKA Poindexter
stock clutch wont hold up to those numbers long at all
Old Jun 28, 2003 | 10:43 AM
SaabGuy's Avatar
I put an act pp with 6 puck unsprung disc in last weekend. The car is only marginally faster. I have still lost boost. Im thinking its the hot muggy weather.
I am able to chirp 3rd on Falken Azenas when they are hot though.
Old Jun 28, 2003 | 10:01 PM
Piranha's Avatar
what 7
If it's hot and humid, that would definately make you put out less power.
Old Jun 30, 2003 | 08:42 PM
turborotarypower's Avatar
that's the ACT pp/ clutch.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Rotate86
May 18, 2018 02:44 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
