Microtech couple of microtech quewstions
Old May 31, 2003 | 11:41 AM
Crusader_9x's Avatar
hey is it etter to use the factory mazda sensors or the new ones that u can order with the microtech? if u get the new ones then do they thread into or fit into the stock location? would the new ones give better or more acurate readings since they arnt 14 years old? or does it really matter?
Old May 31, 2003 | 02:11 PM
TonyTurboII's Avatar
Glock Lover
You usually have to re-thread the holes for the sensors if your using different ones.
Old May 31, 2003 | 11:41 PM
bl|nk's Avatar
Fok mi
microtech runs the BARE amount of sensors to run a car .. so simple it's great.
Air temp gauge.. water temp... those are the only two i can see replacing but not sure if you need to..
can't really do the TPS unless you want to make a custom mount or the CAS... That's it for sensors though right?
Old Jun 2, 2003 | 08:05 AM
No7Yet's Avatar
If you want to replace the stock sensors (with GM sensors, for example), you can do so, you just have to specify that you're doing so at the time you place your order. You'll also need to source the sensors and connectors yourself - BR7 Racing doesn't provide them (other retailers might).
Unlike the E6K, the LT8 can make use of the stock S4 TPS or the stock S5 wide-range. The wiring diagram tells you how. If you want to use a GM sensor, you can, but why?
Brandon
BR7 Racing
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
yr6
Oct 4, 2015 12:23 PM
inMotion719
Sep 28, 2015 03:09 PM
