Will Leaded Race Gas Hurt My Car?
Old Sep 4, 2001 | 04:15 PM
RXTASY1's Avatar
I just got off the phone with my local speed shop to see if I could get some race gas. They have 114 octane, but it's leaded!
They told me that it doesn't have much lead in it and it won't hurt anything except it will clog up your cats. I don't have cats, so that's no problem.
Any of you run leaded race gas in your 7's?
Old Sep 4, 2001 | 05:22 PM
C. Ludwig's Avatar
www.lms-efi.com
Leaded fuel will kill an O2 sensor, in nothing flat. Call, call call. Unleaded race fuel is becoming more and more common. The tree huggers have struck again. Try to look up Trick, Unocal, Cam2, Turbo Blue and Torco online to find a number for distributers. Sometimes the oddest person sells or can get race gas. Unless you're in the middle of nowhere, there's unleaded near you. What kinda mods you running to need that much octane?
Chris
Old Sep 4, 2001 | 07:33 PM
RXTASY1's Avatar
*********** 87 Mazda RX-7 Turbo II ************
*88 J-Spec Engine *TO4 Proturbo *Throttle Body Mod.
*Greddy Turbo Timer *Greddy A/F Meter & O2 sensor *RB Sway Bars
*Greddy FMIC *Greedy Type R BOV *Walbro Fuel Pump *720cc Secondaries
*Apex SAFC *Apex S-AVCR Boost Controller *Apex GT Exhaust
*Bonez Downpipe *Bonez Intake *Bonez Street/Strip Clutch
*ACV Removal *Fuel Pump Re-wire *Ported Wastegate
*Jacobs Rotary Pro Ignition *Magnecore 10mm Wires *RB FCD
*Red Silicone Vacuum Lines *Optima Red Top Battery
*Falken Tires-205/55/R16-Front Nitto NT-555R 225/50VR16-Back
*2700 LBS. *274 RWHP *0-60 MPH @ 4.8 sec.
*1/4 mi. 12.8 sec. @ 110.5 MPH 14 PSI
*********** MOVIES ************
<http://gallery.rx7club.com/images/videos/100plus.avi>
<http://gallery.rx7club.com/images/videos/burnout.avi>
<http://gallery.rx7club.com/images/vi...urbo-incar.avi>
<http://gallery.rx7club.com/images/videos/TurbovsNA.avi>
http://rx7club.wegov2.com/file_depot...nertakeoff.avi
http://rx7club.wegov2.com/file_depot...irst2third.avi
http://rx7club.wegov2.com/file_depot...111/inside.avi
http://home.rmci.net/panther/13_7.avi
*See at: <http://home.rmci.net/panther>/turbo.htm
Old Sep 5, 2001 | 03:38 PM
RXTASY1's Avatar
Found some 107 octane unleaded.
They also had race grade methenol! Hum????
Anybody tried that?
Old Sep 5, 2001 | 06:04 PM
C. Ludwig's Avatar
www.lms-efi.com
Methanol (alcohol) is a definite NO-NO! Engines that run methanol are purpose built for the fuel. A methanol engine will burn nearly twice as much fuel in a given amount of time as a gasoline engine. What this means is you'll be seriously lean. I'd guess the thing might not even run at all. Methanol engines run quite a bit cooler due to low evaporation temp of the fuel, but there's that pesky thirst issue.
Chris
smikels
Aug 18, 2015 01:26 PM
rx7brandon
Aug 16, 2015 10:55 AM
Engine stand ready
Aug 14, 2015 10:26 PM
Wolf_
Aug 11, 2015 04:23 PM
