Microtech W/B data logging??
Old May 28, 2003 | 04:44 PM
astrochild7's Avatar
controlled kaos
W/B data logging??
here is the >?? if i buy a LT8 and get the laptop adapter, i will be able to data log yes.. but can you data log with a wide band O2 or can you only do that when you buy a LT12 and buy the WB data logger and use a laptop or hand controller???? i need to know what the diff...
my purpose is to have a EMS that can data log with a wide band when i'm driving it so i don't have to pay for the dyno crap... i do have experience tunning....
Old May 28, 2003 | 05:13 PM
I F****D a mermaiiiid
Re: W/B data logging??
The only Microtech computer that can Datalog a direct Widerange O2 sensor input is the LT12 and is available as a $50 option. You must purchase a Bosch LSM11 Widerange heated O2 sensor for this capability.
All other computers can only Datalog narrow range (0-1v) sensor inputs. There are a number of wideband kits on the market that can interpret a 0-5v range and scale it down to a 0-1v output that mimics the linearity of the 0-5v sensor.
If you must have onboard datalogging then the only option you have is an LT12 or LTX12 with the WB Datalogging option!
Ray
BR7 Racing
Old May 28, 2003 | 08:10 PM
controlled kaos
thank you i guess i need the lt12 with the wb logging option. i'll be calling you. and changing my order.. thanks again....
Old May 28, 2003 | 10:57 PM
jimmyv13's Avatar
Round&Round not Up&Down
Hey Jodi,
I need to talk to ya man....I tried the number in your sig and it's out of service. Check your PM's....
Old May 30, 2003 | 10:14 AM
Piranha's Avatar
what 7
See my thread about Tech Edge and using the Microtech Datalog (it doesn't work).
Logan Reinisch
44
Sep 17, 2018 12:20 PM
BLUE TII
Sep 26, 2015 10:12 PM
