cd player keeps tunring on and off while driving..
Old May 23, 2003 | 12:11 PM
timmya2's Avatar
Angry cd player keeps tunring on and off while driving..
this is weird but it just started today.. im thinking maybe one of the wires is lose.. but then i saw my auto-metre guage was turning off too..
my friend was the one who installed it.. maybe he used a wire from the cd player to connect to it..
hmm
what could it be guys.. pls help
you how when you go on a bumpy road.. and yur cd player turns off for a second then resumes.. its like that except the car isnt in a bumpy road.. sometimes it happens when the car is at full stop too
it only happened this afternoon
Old May 23, 2003 | 12:22 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Is it a cheap one? Such as Roadmaster/Road Gear, etc. I've heard that they do that from time to time. My friend had a Rampage CD player in his Blazer and it kept turning on and off and the volume would go up like it was possessed. Well one day the volume spiked up and he looked off the road for a second to turn it off and ended up rear ending this old guy's truck.
Old May 23, 2003 | 12:29 PM
anthrax's Avatar
Heck Yes!
I just had a simalr problem with mine...
I have modular Kenwood speakers, and it turned out that one of the cross overs I had in the back behinde the rear curtain had fliped over and was grounding out. This in turn was causing the deck to power off.
Ok so the long and the short of this is check all of your speaker wires (the whole length of the wire) for breaks or cracks or pinched spots. You probably have a shorted speaker wire. This can blow up inxsepensive CD player
Hope this helps
Good luck
anthrax
Old May 23, 2003 | 09:42 PM
timmya2's Avatar
nah it just turns off..
its not a cheap deck...
i think it could be one of the wires huh
Old May 23, 2003 | 09:50 PM
apexkw's Avatar
in slow, out fast!
i would think a bad connection. so yeah i would check the wires
Old May 23, 2003 | 10:11 PM
eddierotary's Avatar
back with rotaries
probably the ground cable is loose, i had the problem before
Old May 23, 2003 | 10:19 PM
O 16581 72452 5's Avatar
The infamous number guy!
I have the opposite problem, mine will sometimes stay on after i turn off the car and the sound will be very distorted.
Old May 24, 2003 | 02:42 AM
poweRX-7's Avatar
sounds like a ground problem... i had the same exact problem that you are describing, and it turned out that my alarms ground was no good. check all your grounds.
Old May 24, 2003 | 03:11 AM
Ultralights's Avatar
agreed, bad earth, or loose power wire
Old May 24, 2003 | 05:14 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
if its a bad ground wire, you will loose memory, if not then its probally the 12V ign wire
Old May 24, 2003 | 01:00 PM
wagondriver69's Avatar
