Distributor again??
Old May 20, 2003 | 03:40 PM
Newbie
Distributor again??
Once again its a 79' with weber carb. 12a. I dont want to have any vacuum advance does the 81-85 have this or is it totally electronic.=========Thanks Guys!
Dave
Old May 20, 2003 | 07:08 PM
RotorMotorDriver's Avatar
Seven Is Coming
The 81-85s have vacuum advance also, but you can just disconnect it and let the centrifugal advance do its thing. Im sure the 79-80 styles would be like that as well...
~T.J.
Old May 21, 2003 | 01:36 AM
Jeff20B's Avatar
Lapping = Fapping
I've got a '79 dizzy and it's got mechanical advance.
Yeah, just get an FB dizzy if you've got a header exhaust. Otherwise, ditch the thermal reactor first. They're meant to run rich with minimal ignition so the 'fire' will stay 'lit' inside the reactor. Then again, you've got a Weber, so you probably already have a header. Go for it!
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
GKW
Sep 28, 2015 04:34 PM
