differences between FD and FC turbo manifolds?
Old May 20, 2003 | 02:20 PM
the_saint's Avatar
What are the differences betweent these two manifolds?
The blocks are relatively the same with different intake manifolds. Can an FC manifold be used on a FD for a T04s?
Thanks
thesaint
Old May 20, 2003 | 03:34 PM
if you mean can a TO4S be mounted on a STD T2 manifold I'd say No becouse of the Clearance of the Engine, Its not it wont fit to the Engine rather the Turbo will foul the Housings.
But if you mean can the TO4S use a Aftermarket manfold ment for a FC then yes.
Chris
Old May 20, 2003 | 05:38 PM
the_saint's Avatar
Chris
Sorry for the confusion.
yes, I am asking if I can use a aftermarket manifold meant for a FC on my FD, in conjuction with a T04s.
Why are there FD aftermarket manifolds for sale that cost almost double compared to FC manifolds?
The pictures look the same.
thesaint
Old May 21, 2003 | 04:59 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
thesaint
Cause its a FD, theres a crap load of parts for them that are like that.
Old May 21, 2003 | 06:18 AM
the_saint's Avatar
But the exhaust side looks very similar. Two exhaust ports, same size housings etc.
the only difference I can see, and correct me if I am wrong is the intake side, which might get in the way.
anyways, I appreciate your patience and help
thesaint
Old May 21, 2003 | 07:13 AM
Fish's Avatar
I think you might find that the exhuast ports on the T11 manifold are smaller than an FD's.
Worth checking.
Dan
Old May 22, 2003 | 10:54 AM
mark57's Avatar
Temple of Cornd0g
A dude here has a TII manifold on his...
....'93 R1 and for the life of me I cannot understand why. They are heavy, flow restrictive and do not fit well, but he uses it. I also understand he'll replace it w/ an OBX unit for the FD
Old May 22, 2003 | 01:29 PM
the_saint's Avatar
Re: A dude here has a TII manifold on his...
Sorry, is that image of a Tii Manifold, or one for the FD?
Thanks
thesaint
Old May 22, 2003 | 01:34 PM
maxpesce's Avatar
Ex fd *****
Also the FC's engine compartment is significantly wider & taller than an FD's A Turbo/Manifold setup for a fc may not fit in the fd engine compertment
Old May 22, 2003 | 08:03 PM
mark57's Avatar
Temple of Cornd0g
That's a pic of my FD manifold
...I need to get a pic of a T2 manifold I guess; I can't do that 'til Sat.
Old May 23, 2003 | 04:15 AM
streetpower's Avatar
It depends on the wastegate postion if some fc manifolds postion the wategate lower so when trying to install on the fd the wastegate hits the subframe.....
What manifold do you have?
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
