funny idle
Old Sep 3, 2001 | 03:38 AM
slilversurfer1973's Avatar
Exclamation funny idle
I've had my car for a couple of years, and just suddenly it starts to idle funny, not always, only when I suddenly rev the rpms and then let it drop back down to idle it always seems like it wants to die.... any ideas
Old Sep 3, 2001 | 12:39 PM
djantlive's Avatar
Maybe you want to scan the code to see if any sensors like TPS is faulty. You can connect the GND and TEN terminals in the diagnosis port underhood w/ a paper clip to do that.
It may also be a vac leak, possibly in the lower intake manifold. This is a common problem. Spraying carb cleaner around the turbo area and see if the RPM surges a little. If it does, you found the leak. If there is a leak and the idle isn't too bad, you may just want to leave it since changing the lower intake manifold will cost you 10+ hrs of labor that requires you to take the upper manifold and turbo apart - lots of work!
Old Sep 3, 2001 | 01:32 PM
spooledUP7's Avatar
There and back again
I agree that you should check your codes. Many of the codes are memorized in the comupter and will show up when you ground the ten connector.
I had an idle problem similar to yours and it ended up being a bad air temp sensor.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Jmpabon93
Sep 30, 2015 04:57 PM
