Tach Problem
Old May 19, 2003 | 01:11 AM
mwatson184's Avatar
holley guy
Tach Problem
Tach bounces at the following times.
1. When in neutral, reving the engine.
2. In 1st-3rd gear, while accelerating.
Does not bounce at these times
1. At a stop, idling
2. At a stop, reving engine with shifter in 4th gear/5th gear position.
3. While decelerating in any gear
4. While accelerating in 4th/5th gear.
I am curious to find out why the tach only bounces in 1st through 3rd and only while the gas pedal is pressed. Any time the shifter is in the 4th/5th position tach holds steady and strong. Anybody have any ideas? Thanks guys.
-Marques
Old May 19, 2003 | 01:25 AM
wwilliam54's Avatar
it WILL run
what year
Old May 19, 2003 | 01:34 AM
mwatson184's Avatar
holley guy
sorry, forgot about that part, it's an 80.
This is my first fb, (I have a couple fc's) so now I have to learn all the little problems about these also.
Old May 19, 2003 | 01:42 AM
wwilliam54's Avatar
it WILL run
hehe its an SA
I have no Idea, but maybe someone will know
Old May 19, 2003 | 11:30 AM
mwatson184's Avatar
holley guy
bump. am I going to have to figure this one out myself? I hate doing that
-Marqueds
Old May 19, 2003 | 06:12 PM
specRX7_22's Avatar
check to make sure the trailing ignitor is tight, it could be tiny bit loose. also, it could happen if the motor is surging from something voltage related (alternator, etc).
the fact that it does it in some gears and not others doesnt make sense to me.
Old May 19, 2003 | 11:50 PM
mwatson184's Avatar
holley guy
the tach will be fine and steady in 1st through 3rd on decel. As soon as my foot touches the pedal the tach starts bouncing again.
Upon further inspection today I found that it will read the engine RPM up until 1400 rpm in neutral, anything past that it will just start bouncing again.
I thought that this would be one of those common problems that someone could just fire a quick answer for, oh well, i'll get it figured out.
Old May 20, 2003 | 05:48 PM
yeah check the coil wires. i had my SE do this once, one of the wires was lose.
job
Old May 20, 2003 | 06:44 PM
RotorMotorDriver's Avatar
Seven Is Coming
Dont the SAs run the tach off the leading ignitor because the trailing only operates part of the time?
~T.J.
Old May 20, 2003 | 08:39 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Yes, I believe you're right. The trailing plugs would be cut when the thermal reactor wasn't getting enough unburnt gas to continue the combustion in the thermal reactor. Bitchin' huh? If your motor was running too clean, the little weasel would dirty itself up. Nice!
There is another possibility, too. The '80 models had the ignitors mounted remotely in a little box on the fenderwell. The problem with this arrangement is that the triggering pulse to the amplifier (ignitor) from the distributor is so weak that due to the extra wire length involved and the close proximity of the two leads, cross-triggering can occur and that might cause the tach problem described, although for the life of me I can't understand why it would be gear dependant. You can disable the trailing-cut "feature" by jumpering the +12V terminals on the coils, but outside of replacing the '80 electronic distributor with an '81-above unit, or possibly rewiring the sending wires with some shielded wire, there's not a lot that can be done about the cross-triggering if indeed that is what's happening.
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 18, 2015 07:13 PM
newtgomez
Sep 13, 2015 07:39 PM
