how do you PROPERLY lean out w/o power fc?
Old May 18, 2003 | 01:22 PM
chiminoid's Avatar
no more problems, PLEASE!
is there any way to safely and properly lean out your fuel mixture w/o having a programmable ecu (on a stock ecu)?
i figure you could bolt on a flow mod but that's not what i would consider safe and proper.
Old May 18, 2003 | 01:24 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
NO!! I don't know what planet your living on but in the world of rotary engines, running lean is VERY BAD.
Old May 18, 2003 | 01:35 PM
Nathan Kwok's Avatar
If you want to lean out a stock car to get more power (they do run pig rich stock) you could use a S-AFC. Basically a piggyback fuel controller. I think there are other piggyback boxes that do the same thing.
Old May 18, 2003 | 01:49 PM
reza's Avatar
use open intake, put in downpipe, midpipe, and high flow cat back.
put in efini y-pipe. use homedepot boost controller to prevent boost reaching more than 11psi.
now that should bring the AF from 10 to around 11
Reza
Old May 18, 2003 | 04:42 PM
chiminoid's Avatar
Originally posted by TopSecretUSA
and enjoy it while you can because you will probably pop your motor.
actually, most of the people on this board will tell you that you can throw on all the bolt-ons you want as long as you keep stock boost
Old May 18, 2003 | 04:47 PM
JoeD's Avatar
Most of the people on this board are not on their original engine, either.
Queppa
Nov 18, 2024 03:47 AM
R7rexy
19
Sep 2, 2015 10:24 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
