Another overheating problem
Old Sep 2, 2001 | 03:57 PM
7Rebel's Avatar
My 1987na has been overheating so I replaced the temperature gauge. When I replaced it I noticed that the bottom half of the old temperature gauge was broken off and I couldn't find it. What are the chances that the bottom piece is lodged somewhere in the engine blocking the flow of antifreeze? That would SUCK! Has this happened to anyone before? My car is still overheating. So far I replaced the 2 radiator hoses the caps, the temp gauge. the catalytic converter, and the pre cats.
any input would be great
Old Sep 2, 2001 | 04:57 PM
deadof_knight's Avatar
Im ot trying to be smart@$$ but
you mean sensor right not gauge ,gauge = inside the car ,sensor is the motor yes ?if it did break it could cause a problem but i cant see it being overheating that bad ,its not that big but hey ive seen weirder i guess ...
Old Sep 2, 2001 | 05:22 PM
HAILERS's Avatar
HAILERS
Go out to your car and remove the thermostat completly. Go drive the car. Does it overheat still. If it does that eliminates the thermostat. If it just runs in the lower 1/8th of the gauge go get a Mazda thermostat. Are you losing coolant to the overflow tank?I doubt that that little tit off the sensor could cause overheating.
Old Sep 2, 2001 | 06:15 PM
7Rebel's Avatar
actually I ment the thermostat
it was the bottom half of the thermostat that was missing.
Sorry for the mistake
Old Sep 2, 2001 | 06:23 PM
7Rebel's Avatar
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
erevos
Sep 15, 2015 09:19 AM
