how much power?
Old May 15, 2003 | 01:10 PM
santology's Avatar
how much power?
I tried searching but could not find what I needed.
How much power do you guys think I'm putting to the ground ? I have '94 R2 with pf intake, catback, and a power fc running 12 lbs and base map?
Old May 15, 2003 | 01:25 PM
Scrub's Avatar
bow leggin'
probally around 280 or so.
Old May 15, 2003 | 01:31 PM
Dragonz818's Avatar
I would say more like 260-270 rwhp
Old May 15, 2003 | 01:51 PM
XSTransAm's Avatar
Ee / Cpe
i would agree with the 260-270 because you have stock dp... get aftermarket dp and intercooler... bump your boost... and WOOSH
Old May 15, 2003 | 01:55 PM
matty's Avatar
with precat and cat in place...i would guess 250rwhp
Old May 15, 2003 | 04:06 PM
seandizzie's Avatar
hey santology do you live in fort walton beach? just curious... If so I am the guy with the bule touring model that you talked to in walmart parking lot. later....
Old May 15, 2003 | 04:17 PM
apneablue's Avatar
^^^^ What He said ^^^^
Old May 15, 2003 | 04:18 PM
scratchjunkie's Avatar
sexy no jutsu
mid 200's. get that DP in there! hurry up!
Old May 15, 2003 | 05:40 PM
I agree. I put down 285.9 w/ intake, dp, mp, and catback w/ 12psi and PFC using the Base Mod Map. FMIC is sitting here and slowly getting polished, then I can make a 15psi run on the dyno.
Old May 15, 2003 | 06:28 PM
Sprockett's Avatar
Former Rotorhead
What about a guy with an intake (blitz), dp (pettit), and cat-back? Sorry to jump into this, but I'd kind of like to know, too.
Old May 15, 2003 | 08:35 PM
matty's Avatar
there is a guy that just posted 330rwhp at 10psi creeping to 12psi with stock motor and turboes with a FMIC..imagine that. My experience shows that an ic adds very little rwhp unless u up the boost.
With your mods and boost i put down 296.5. I added a SMIC and got 305 with more tunning. Once i rasised the boost the higher hp came.
Old May 15, 2003 | 08:41 PM
matty's Avatar
u need a power fc or some type of ecu...but get a pwer fc!
i would say around 250ish maybe alittle more
Old May 15, 2003 | 09:17 PM
Sprockett's Avatar
Former Rotorhead
Yeah I know - need money first, though
Old May 16, 2003 | 05:09 AM
Batmobile's Avatar
With a full exhuast, FMIC, intake, no ecu, I was able to put down 308rwhp, and 276tq.
Old May 16, 2003 | 07:06 AM
JammerRX's Avatar
you're puttin 255 at the crank stock, so you figure a 10-15 hp addition with the cb and a 5-10 with the intake...255 + 15 + 10 = 280 at the flywheel * .85 (assume a 15% loss in drivetrain could be more) = 230 at the wheels... and with the boost turned up 2 more psi I would guess 10 hp per psi maybe more so somewhere around 250
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
