again with the problems
Old May 14, 2003 | 09:29 PM
Angry again with the problems
gentleman I have a small problem and I don't know what the hell happened to my rx. I pulled the choke and started my car, after like 1-2 minutes it just straight died, I don't know how else to explain it. It flooded and now I can't do a damn thing with it I need some advice on what is wrong and what I can do about it. I live in seattle so if anyone knows where a good place to get it fixed that would be a great help also.
thanks a lot
zach
Old May 15, 2003 | 02:54 AM
karism's Avatar
Adolf Hitler Verfechter
You can do either of the 2 options given here,both work good.
1.You can put some ATF (automatic transmission fluid)down the chokes of the carb.
25cc would be enough for each choke.Depress the accelerator to the floor,and keep it there untill it starts,keep it running.You will see big white clouds of smoke out of the exhaust,dont be alarmed its the atf burning.Keep it running and go for a drive,do not shut it off before normal operating temp is reached.
2.Turn out your spark plugs,remove your coil ht leads,and crank the engine for aprox 15 seconds.Clean and dry the spark plugs and reinstall.
It is a good idea to replace the plugs when it was flooded.
Hope this helps
Karis
Old May 16, 2003 | 06:21 PM
I tried it and that didn't work, I have a feeling that it has something to do specifically with the choke. Any other ideas gentleman
thanks again
zach
Old May 16, 2003 | 11:59 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
There's a Seattle in South Dakota?
Old May 17, 2003 | 05:19 PM
Rx7carl's Avatar
Airflow is my life
Pop the top off the aircleaner and look to see if the carb is flooded with fuel.
Old May 19, 2003 | 03:56 AM
karism's Avatar
I agree with Rx7 Carl. Take the aircleaner of,with the pump running,check if there is fuel running down the chokes.
Old May 24, 2003 | 07:42 PM
still not working tried all that mess can't finger it out help I gotta get to work on tuesday
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
