porting
Old May 5, 2003 | 12:00 AM
84stock's Avatar
porting
Hello, I have a stock 84 rx7gsl 12a. it needs a little more power. It has no cat, turbo muffler and a nikki carb. I took the spring out of the vaccuum secondary diaphram and didn't see much difference ( I wonder if the secondaries are even opening). Power seems to top out at 6800 rpm. My main question, is it possible to do a street port without removing or rebuilding the engine. Also, since the cat is gone, and exhaust flows well, would a header make a measureable difference. Carb works well, but can't find the idle screw. Choke works but fast dile doesn't. Thanks for any advice.
Old May 5, 2003 | 12:07 AM
Mr. ImportGuy's Avatar
Looking for Another RX7
The header will make a nice differance. As far as streetport with out taking the motor out, no not if you want the motor to work agian lol.
Old May 5, 2003 | 12:09 AM
84stock's Avatar
how about the port job. How much $$ and mow much difference in performance?
Old May 5, 2003 | 12:17 AM
http://www.pineappleracing.com/index.html They do porting, also www.mazdatrix.com is another good site.
Old May 5, 2003 | 09:29 AM
metalliman's Avatar
The header will probably give you the best bang for your buck. If you want to port your engine, you'll probably want to replace your carb with a side draft or a holley and put on a full exhaust to really take advantage of the port job.
Old May 5, 2003 | 02:41 PM
jayroc's Avatar
No, it's not possible to do a port job to a rotary without taking it apart.
Unless there's some new technique that I'm unaware of.
heh
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
