Coolant o-rings
Old May 1, 2003 | 01:00 PM
twan's Avatar
Cool Coolant o-rings
Sup, Fellas?
Quick question. Anybody know of, heard of , or have urethane coolant o-rings. Mine are slowly but surely going. Also thinking of sealing the coolant system with ceramic coat. Holla Back!!!:
Old May 1, 2003 | 03:07 PM
Scalliwag's Avatar
WingmaN
By using a coating in the cooling system you will risk the heat not transferring to the coolant and to the radiator. That would cause the motor to overheat quickly if I am right. The ceramic would be a thermal barrier but it would not keep areas that generate heat from getting hot. It would just not leave a path to transfer the heat too. This is redundant but I don't feel like editting
As far as seals;
Are you sure you are not talking about teflon encapsulated silicone? Viton would be another good material, but I don't know of a urethane that meets the temp rating.
Old May 1, 2003 | 06:00 PM
Gearhead's Avatar
Holla Back???
Old May 5, 2003 | 12:03 AM
t-von's Avatar
Rotor Head Extreme
Originally posted by Gearhead
Holla Back???
Uhhhh are you being sarcastic, or do you really not know what that means?
Old May 5, 2003 | 04:49 PM
Gearhead's Avatar
sarcastic
Old May 7, 2003 | 05:37 AM
Simplecat's Avatar
sarcastic
see, thats sarcasm, your previous post wasn't as purely sarcastic..
GREG
*sarcasm coach*
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
BLK 93
Sep 28, 2015 01:45 PM
