Low oil pressure at WOT
Old Apr 30, 2003 | 07:53 PM
af908's Avatar
I have an autometer oil pressure gauge and sending unit. When cruising my oil pressure is around 50-75 psi. However during WOT the pressure doesn't really go up, if anything it starts to go up then goes back down to around 60. I am also running 10w-30 mobil 1 synthetic oil. Is all this normal? i searched but found nothing.
Old Apr 30, 2003 | 08:11 PM
Kento's Avatar
2/4 wheel cornering fiend
Oil pressure is rpm-related, not throttle-related. If it drops more than the oil pressure reading at steady 3000-3250 rpm cruise, I'd say the gauge is screwed up, or you may have a leak somewhere.
Old Apr 30, 2003 | 08:50 PM
af908's Avatar
even when the rpms go up its always pretty constant at 60-65 psi on the highway and i hear it should go up and go up to about 100. yes i do have a small oil leak about 3 drips a day but would that really influence oil pressure THAT much? what are symptoms of a bad oil pump?
Old May 1, 2003 | 04:14 PM
af908's Avatar
can somebody please help?? is it normal for my oil pressure to stay constant like this???
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
