Front wheels squeaking...
Old Aug 29, 2001 | 01:07 PM
vobs's Avatar
Alright, at low speeds (I'm sure at high also I just can't hear them) my wheels sqeak while moving. I would assume that my wheel bearings are shot. Are they easy to replace? And where can I get new wheel bearings and for how much? Thanks in advance.
Matt
Old Aug 29, 2001 | 01:56 PM
vobs's Avatar
I went to mazdatrix's website and found the inner, outer, and seal for the front. Next I checked out autozones website and all they had was a single bearing and a seal. Why don't they have two bearings available, anyone have any experience? Thanks ahead.
Matt
Old Aug 29, 2001 | 03:03 PM
SpeedRacer's Avatar
Formula Mazda Driver
Is it a constant squeel, or does it start,top, start, stop. Could just be dirty or dusty brakes, and a slightly warped rotor.
Old Aug 29, 2001 | 03:12 PM
vobs's Avatar
Actually it is a start, stop, start, stop squeal. So dust brakes and a warped rotor could be part of the problem. But if I remember right when I had the wheel off last, I could ever so slightly jiggle the wheel back and forth by pushing and pulling on each side, which I've heard means the wheel bearings are bad or at least need to be tightened (from how to on www.fc3s.org). Maybe I'll start there. Does anybody else have any info on why the parts store only sells one bearing for the rx7 and mazdatrix lists a inner and outer? I looked at the parts store bearing and it looks physically a lot bigger than the bearings that are shown on the mazdatrix website. Thanks in advance.
Matt
Old Aug 29, 2001 | 08:36 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Matt
The parts stores probably don't carry just the front wheel bearings- "officially" they aren't replaceable, you have to replace the entire hub... but... it can be done. Read the FAQ on the Mazdatrix website.
Brad
fidelity101
13
Aug 31, 2015 07:47 PM
