idle adjustment
Old Apr 24, 2003 | 11:28 PM
93BlackFD's Avatar
built my own engine
idle adjustment
i've been trying to adjust my idle all day
my TPS is in spec, my throttle cable was too tight, this fixed the high rev on idle
i've been adjusting the air bleed screw and the primary butterfly screw
when i crank the car now, it wants to die, until i give it some gas, then it holds at about 800-900
when i turn on the a/c, the idle drops to 600-700
are these symptoms of a bad ISC? where the hell is that anyways? I can't find a single diagram that shows it's location
Old Apr 24, 2003 | 11:29 PM
93BlackFD's Avatar
built my own engine
also, if someone could take a flathead screwdriver to their air bleed screw, and tell me how many turns it takes to get it fully in (so i can tell how many to back mine out)
and then goto your primary butterfly screw and tell me how many threads are showing above the nut
that would help tremendously!
Old Apr 25, 2003 | 07:33 AM
paw140's Avatar
Someone (damian?) had a good thread on adjusting the idle with the past couple of months. There is also one posted by ArchangelX last week I think. You should be able to search for them.
Old Apr 25, 2003 | 10:56 AM
93BlackFD's Avatar
built my own engine
yeah, i can't locate the idle speed control solenoid
Old Apr 25, 2003 | 11:10 AM
poss's Avatar
Slower Traffic Keep Right
the isc is a cylinder shaped solenoid that is on the firewall side of the UIM. most of it is black and comes after the throttlebody in the intake path.
Old Apr 26, 2003 | 10:53 AM
93BlackFD's Avatar
built my own engine
haha, so i eliminated that with my block off kit, I can run without it, right?
so i should have a high idle when not on A/ C ?
DerpyToast
14
Nov 23, 2024 05:19 PM
Microtech
Nov 21, 2015 10:20 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
