inaccurate speedometer
Old Apr 21, 2003 | 06:45 PM
curlybillbrosie's Avatar
I know speedometers dont usually show your exact speed on the dot but mine is usually fast by about 5 mph even at sub highway speeds. If the speedometer says 70, im actually doing more like 65 or 64. Just curious, does everyone have this problem or is it just me?
Old Apr 21, 2003 | 06:54 PM
adam c's Avatar
Cheap Bastard
My speedometer is pretty accurate. Do you have stock size tires......225/50/16. If you do, and they are nearly worn out, that would contribute to your problem.
Old Apr 21, 2003 | 06:58 PM
Mahjik's Avatar
Mr. Links
Re: inaccurate speedometer
Do you have stock wheels/rims?
Old Apr 21, 2003 | 07:27 PM
yes. i have been using the stock rims and original tires which are worn a bit but still have a little life left.
Old Apr 21, 2003 | 07:38 PM
Mahjik's Avatar
Mr. Links
Hmm, how are you telling that your speedo is inaccurate?
Old Apr 21, 2003 | 08:54 PM
rboorgu's Avatar
Mine does this as well. In fact, i have a power fc and the speed shown in the commander and my speedo differ by 8-10 kmph ie 4-5 mph.
Don't know the cause but I would like to fix it.
Raj
Old Apr 21, 2003 | 09:00 PM
ejmack1's Avatar
Lawn Ornament
the power FC shows your speed too? sweeet!
Old Apr 21, 2003 | 09:03 PM
powermalex's Avatar
GPS
Find a GPS to borrow.
I use my Garmin to check speed mine is off only +/- 2 mph based on cruise on steady at 60mph
Old Apr 21, 2003 | 10:00 PM
Mahjik's Avatar
Mr. Links
Also, check these threads:
https://www.rx7club.com/forum/showth...hreadid=165838
https://www.rx7club.com/forum/showth...threadid=26343
https://www.rx7club.com/forum/showth...threadid=22619
Old Apr 21, 2003 | 10:58 PM
nickpapagiorgio's Avatar
Keep in mind that if your speedometer is off, your odometer could also be off which could mean you actually have less or more miles than your odometer shows.
-Kevin
Old Apr 21, 2003 | 11:05 PM
Fd3BOOST's Avatar
Recovering Milkaholic
You can easily recalibrate the speedo guage using the tach.
Old Apr 21, 2003 | 11:21 PM
poss's Avatar
Slower Traffic Keep Right
how?
Old Apr 21, 2003 | 11:22 PM
Fd3BOOST's Avatar
PM me if you want my number and I can walk you through it. It's pretty simple and takes about an hour or so to do it.
-Dave
Old Apr 22, 2003 | 01:15 AM
FD Seeker's Avatar
Rotary Optimist
Using a GPS, I have noticed that my speedo is about 5-6mph optimistic at freeway speeds. My stock tires are maybe 50% worn.
Old Apr 22, 2003 | 02:26 AM
rynberg's Avatar
Hmmm...I guess I'm the lucky one. My speedo seems to be exactly on if I compare my speed to my rpm using the known gearing of the car. Redline in 3rd gear is just a tad over 100 mph....
Old Apr 22, 2003 | 02:44 AM
try cruising at 60 between mile markers, thatll tell for sure.
Old Apr 22, 2003 | 08:48 AM
n/arotary's Avatar
Or you can see from the mile markers how far your odometer travels in a mile to get a good ratio of how much your speedometer is off.
