Still looking for 12's at the track...
Old Apr 20, 2003 | 10:29 AM
fastrx7man's Avatar
Looking for 10's
22 races and still haven't made it into the 12's. I am having my clutch replaced next week. It's been slipping bad for the past month ( last 7 runs). Once the new clutch is in I will finally put the ET streets on and run 100 octane. I will not be happy until I am running low to mid 12's. (Then I will shoot for high 11's...) Here are all my runs and times...
fastrx7man's Avatar
Looking for 10's
See sig for mods...
Old Apr 20, 2003 | 12:44 PM
streetdreamzny's Avatar
i think you could make it to the 12's with your current setup you have a few more mods than me and i run 12.3
whats your 60 ft time thats probably whats stopping you
Old Apr 20, 2003 | 02:46 PM
RXTASY1's Avatar
If you get your 60' times below 2 seconds, you will be in the 12's!
What kind of tires you running?
Old Apr 20, 2003 | 08:50 PM
fastrx7man's Avatar
Looking for 10's
My best 60' has been 2.1374, but I missed 3rd gear on that run. My average 60' has been 2.2598. I am running Yokohama AVS ES100 (275x35x18) in back. With my clutch slipping the way it is I have choosen not to do a burn out the last 2 times to the track. I wanted to save my clutch as long as possible.
Hopefully I will have enough time to break my new clutch in so I can take it to the track Wed. April 30th.
Old Apr 21, 2003 | 09:01 AM
pp13bnos's Avatar
Pineapple Racer
Is the car tuned in? Reason I say that because I'm running a 12.600@116.50 with my sig. CJ
EDIT: uhhh sorry about that....seems my sig does'nt realy say anything.
I'm running a downpipe, mid pipe, stock cat back, m2 medium style, (spyfish ic) efini Y-pipe, m2 intake, power fc, and a profec b@13psi.
Old Apr 21, 2003 | 10:17 AM
airborne's Avatar
King of the Duct Tape
it looks like your mph is all over the place. in that sheet you trapped over 110mph 3 times, thats enough for 12s. but obviously if the clutch is slipping that can account for a lot. even on street tires you should make it to 12s with that setup.
Old Apr 21, 2003 | 11:37 AM
SPOautos's Avatar
Hey, where did my $$$ go?
Every single one of your runs would have touched 12's and some real low 12's if you can get your 60 foot down to 1.90
Part of the problem is probably your wheels and rubber. If you still have your stock wheels, you should cover them with drag radials and run those at the track. You'll be in the low mid 12's like that.
Also, you shouldnt be needing a new clutch with those 60 foot times since your already have a ACT clutch. Or is your sig talking about the clutch your fixing to use?
STEPHEN
Old Apr 21, 2003 | 02:09 PM
efiniracing's Avatar
"(275x35x18) in back"
It'll be hard to get your 60'ft times below 2 w/ those wheels. Put your stock rims back on w/ somne good rubber, do a goood burn out, launch at a high rpm and make sure that you power shift. You'll get to low 12's sooner or later.
Old Apr 21, 2003 | 07:53 PM
fastrx7man's Avatar
Looking for 10's
Thanks for the input. As for the clutch...I currently have the ACT street/strip. I am going to the ACT extreme clutch. As the the wheels...I am taking my stock wheels and putting ET streets on them.
As for my trap speeds being all over the board, it probably has alot to do with me missing 3rd gear so often. I will eventually get that figured out.
Old Apr 22, 2003 | 12:29 AM
get a torque brace that has seemed to help a bunch of people but i dont have one or a getting into third problem so i couldnt say for sure
Old Apr 22, 2003 | 12:33 AM
SPOautos's Avatar
You dont need anymore than the ACT street strip clutch. If your frying the clutch its cause your sliping it for to long at high rpms when you come off the line. The clutch itself can handle way more power than your giving it.
I used to run 12.3's @ 113 with 1.8x 60 foot times on Nitto drag radials on the BONE STOCK clutch.
STEPHEN
Old Apr 22, 2003 | 12:37 AM
88IntegraLS's Avatar
Displacement > Boost
I wonder what you would run with the stock (light) rims and some race rubber. What is the total diameter of your 18" wheel / tire combo compared to the stock diameter? What is its weight? Wheel weight and diameter is just like vehicle weight and gearing, respectively.
Old Apr 23, 2003 | 07:22 AM
Kiflin's Avatar
Wow, you had some horrible reaction times when you began racing, but is typical. If you got more practice and shed off .3 seconds in reaction time you would be in the high high 12's. But like I said, takes a lot of practice, or just good luck to hit .5-.6 second reaction times.
Old Apr 23, 2003 | 08:55 AM
fastrx7man's Avatar
Looking for 10's
Maybe I am wrong but I don't think reaction time has anything to do with ET times. If you know something I don't please let me know...
Old Apr 23, 2003 | 09:16 AM
pp13bnos's Avatar
Pineapple Racer
Reaction time has nothing at all to do with time. CJ
Old Apr 23, 2003 | 10:01 AM
spoolin's Avatar
yeah, you could fall asleep at the tree. the time doesn't start until you move....that's what the staging lights are for- for the timing system to know when you're ready and when you leave the line.
Old Apr 23, 2003 | 10:03 AM
SPOautos's Avatar
Yea, they dont start the clock till your front tires move and trip the clock. You can sit at the line for 10 minutes and the clock wont start till you take off.
Your reaction time is a concern is during bracket racing when its down to who crosses the line first, but even then its not added into your time. Your time is the same no matter what, but since your reaction time was slow you crossed the line 2nd and even though your time was better you loose cause you crossed 2nd.
Anyway, it was already said, I just thought I would take it a little farther and explain it some.
STEPHEN
Old Apr 23, 2003 | 07:19 PM
fastrx7man's Avatar
Looking for 10's
The new clutch is installed and I just picked up my stock wheels with brand new Nitto Drag Radials on them. I am looking to have the clutch broke-in by next Wednesday. I better get my 60' under 2 seconds...
Old Apr 23, 2003 | 08:51 PM
Kiflin's Avatar
Wow, as you can see, I have never raced my fd, nor do I ever plan to.
But thanks for the info guys, I honestly did not know that.
Old Apr 24, 2003 | 10:54 AM
tcb100's Avatar
DinoDude
FastRXman, hate to mention it now, but you oughta consider swapping those Nittos for Thompson ET Streets before you use them.
I own both the Nittos and the ET streets and there is no comparison at launch. Nittos just did very little for me. They were only a bit better than my Michelin Pilots & frankly I'm not even sure they WERE better. But the ET streets produced a whole new sensation, a slingshot feeling - they really hook. The ET streets are easier on the rear-end too.
Missing third is easy to do. If you ever get a new tranny (as I unfortunately need to do) however, the new version has a real strong detent spring that makes getting into 5th a real deliberate act. I also have a torque brace. If I miss third again I should turn in the car. I have not run the car yet this year so we will see if the new tranny and brace really work this weekend.
Consider the Pettit launch kit too. Cheap and easy to install. Absolutely reduces wheel hop.
I run 12.06 with a cat & I WILL break into the 11s this weekend. With a mid-pipe you will waltz to the 12s and maybe the 11s if you have a good tune.
Old Apr 24, 2003 | 10:21 PM
ErnieT's Avatar
Living life 9 seconds at a time
Its obvious you know nothing about drag racing so don't comment when you don't have a clue. Reaction times have nothing to do with your et. Your time doesnt' start till you trip the light.
The only thing he needs to do is get his 60' times to about a 1.80 and he'll be running mid to low 12's. High 11's on 15psi.
Old Apr 25, 2003 | 06:28 AM
Kiflin's Avatar
I found this out the hard way, like I said, I have never dragged the car.
But honestly, being word raped by Ernie did do a number on my ego...
Old Apr 25, 2003 | 11:14 PM
fastrx7man's Avatar
Looking for 10's
Thanks for the insight...I am returning the Nittos tomorrow and having brand new ET Streets installed on the stock wheels...I can't wait to get to the track!!!!
Old Apr 26, 2003 | 01:21 AM
vosko's Avatar
Just Call Me Terminator!
beforewarned you might break an axle with ET streets........ besides that they kickass
