Garrett T3/60-1 W/.48 A/R turbine
Old Apr 17, 2003 | 09:46 PM
marcus219's Avatar
FC Mobsta
I'm going to be tackling the TII swap into my s4 this summer. Purchasing engine and trans from fc3s, going to be rebuilt, streetported, 80psi OPR, stock 2mm 3 piece seals. I'm looking at turbos, new territory for me when it comes to different turbines, etc, and how the effect turbo performance (ie lag, etc). I was looking at the Garrett T3/60-1. I'm looking for something that will work for street/strip, moderate spool up time, and something that can run moderate boost levels efficiently.
http://store.yahoo.com/cheapturbo/88marx7ust3.html
Do you think this will work.......I'm going to be using my never before tuning skills with an E6k most likely. Setup..
13BT rebuilt, ported
stock primaries, 1600cc secondaries
E6K
Greddy FMIC
Basically any help, links reccomendations, to any turbo that would work with me. high 300rwhp to low 400rwhp is my goal. Thanks.
Old Apr 17, 2003 | 10:10 PM
marcus219's Avatar
FC Mobsta
I'm also looking at these T4 turbos:
-T4/60-1 w/ .70 turbine
http://store.yahoo.com/cheapturbo/gart0t4w70tu.html
-T4/60-1 w/.84 turbine
http://store.yahoo.com/cheapturbo/gart0t4w84ar.html
-T4/60-1 w/.96 turbine
http://store.yahoo.com/cheapturbo/gatot96ar.html
Input on which will be better for street/strip...the "middle ground" turbo is the T4/60-1 w/ .70 turbine isnt it? How much of a difference in spool up and effience between them. Thanks a ton.
Old Apr 18, 2003 | 12:44 AM
Marshall's Avatar
The T3 and T4 will require a different exhuast manifold, so decide that first. The 60-1 w/.96 turbine is a proven 400 rw maker with decent spool.
Old Apr 18, 2003 | 02:43 AM
AJC13B's Avatar
10.32 @ 133
Are you wanting boost at idle? Jesus
There should be a law that states a turbo on a rotor should come with a 1.0 or larger exhaust housing!
Get a GT35/40 with 1.06 exhaust housing
Old Apr 18, 2003 | 10:24 AM
chuck8313BTSDS's Avatar
Marcus219
I have a T3 60-1 .82 a/r stage 3 wheel. At 19-20psi the car did 11.61 at 124.89mph last weekend. I also bored the exhaust side of the turbo for better flow..?? With this turbo the car does not feel like a turbocharged rotary. 9.4 rotors. No lag at all. I get 15-17psi in the middle of first gear. If you go with a .48a/r I also think you may get boost at idle. I also purchased my turbo from cheapturbo.com. Get the .82 a/r with the stage 5 wheel or the 1.06 a/r with the stage 3 wheel. That is the smallest I would suggest. When I bought my turbo from them they did not have the above setups.
I do drive the car on the streets on the weekends and to work once or twice a week, 20 mile one way.
Old Apr 18, 2003 | 10:39 AM
marcus219's Avatar
FC Mobsta
Thanks for the info guys....15-17psi in 1st, damn. MORE INPUT!!!
Old Apr 18, 2003 | 12:35 PM
importboi22's Avatar
Hks Ownz Me (
yea im copying chucks setup except i went with S5 NA rotors higher compression helps build boost faster learned that little fact from a few turbocharged hondas that ive help work on myself!
Old Apr 18, 2003 | 04:19 PM
Hks Ownz Me (
hey chuck do you have a time slip what kinda 60 foots did you have? what are you others mods and is it a stock port motor? thanks
Old Apr 18, 2003 | 04:41 PM
importboi22
A link to some pictures and time slips are on my profile page. Please dont laugh at the back yard work. I am not to interested in the looks or how long the motor will last, just the power. I drive the car to the track, 30 miles round trip from the house. last week I ran Wen, Fri, Sat and Sun. I average 5-6 run down the 1/4 mile everytime I go. Useing the 9.4 rotors was a money issue. TurboII rotors are hard to find, N/A motors are everywhere for allot less.
chuck
Old Apr 18, 2003 | 05:22 PM
Hks Ownz Me (
nice custom fabbin i like it!
Old Apr 18, 2003 | 05:48 PM
marcus219's Avatar
FC Mobsta
Nice, "just the power"..I like that!
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Rotate86
May 18, 2018 02:44 PM
