wierd buzzing sound from dashboard??
Old Aug 27, 2001 | 04:54 AM
LLman's Avatar
Lucky owner
Unhappy wierd buzzing sound from dashboard??
Recently I noticed that somewhere in dashboard comes weard buzzing sound when engine is running the tone gers higher when rpm's are rising and it dissapears arond 4500rpm area.
sounds like it comes from cpu but I'm not sure???
Any ideas what is going on???
LLman
Old Aug 28, 2001 | 02:25 PM
Aaron Cake's Avatar
Engine, Not Motor
Cool
Could be anything from a loose something or other in the dash, to the ignition system interfering with the stereo.
The CPU is in the drivers side kick panel, so you should be able to get your head down there and listen to see if the noise is really coming from the CPU.
Old Aug 29, 2001 | 01:48 AM
LLman's Avatar
Lucky owner
It can't be stereo system 'cause it sounds when the stereo is turned off too. And it's definetly comes from CPU ... I Cheked.
What is making that sound in CPU thats wierd???
LLman
Old Jun 29, 2002 | 12:46 PM
Josepi's Avatar
Despise Enmity
LLman
Ever get this resolved? Anyone else have this problem? It sounds like what my car started doing yesterday...it's got me a lil on edge
Old Jun 29, 2002 | 01:56 PM
brap brap
I'm having the same problem, or similar. it makes a buzzy/chirpy noise whenever taking off into higher gears.. then goes away, just like he stated.
Old Jun 29, 2002 | 02:05 PM
Aaron Cake's Avatar
Engine, Not Motor
It's the shifter vibrating. Highly doubt it has to do with the CPU, unless the CPU has found a fault with the power steering and is trying to beep out a code. The issue would then be cold solder joints on the little speaker so that you can properly hear the code.
Old Jun 29, 2002 | 02:12 PM
Bambam7's Avatar
I came, I saw, I boosted.
KILLER BEES!!! OH MY GOD!! KILLER AFRICAN BEES!!
AAAHHHHH!
Old Jun 29, 2002 | 03:56 PM
Josepi's Avatar
Despise Enmity
Seriously it's not the shifter. It's completely RPM dependent. This is in neutral, so that rules out the whole tranny. At first, I thought it'd be the speedo gears going out, but it'll do it while parked. The first time it happened, it was while starting, then it disappeared for two days, then reappeared ever since. Just looking for ideas...it's not killer bees , and it's not the stereo (put the ear to the speakers even...). After 3K with the windows down you can't hear it so it's not too bad, it's only ******* pissing me off at stops...does the CPU have ANYTHING that would make noise? Relays, connections, peizos? If anyone doesn't come up with a clear answer i'm going to go buy a stethoscope and find out where it's coming from tommorow...
Old Jun 29, 2002 | 06:02 PM
Aaron Cake's Avatar
Engine, Not Motor
Does the beeper in your CPU work correctly? It sounds like it is trying to beep out a code (most likely power steering) and the sound is getting garbled by an intermittant beeper.
Old Jun 29, 2002 | 06:40 PM
Mobius's Avatar
here's a thought. If you have power steering. Then it could be the power steering CPU, located under the dash Directly behind the steering wheel. Its a silver box.
Now, the reason it may be power steering CPU is because the engine turns the power steering belt which is monitored by the power steering CPU. Perhaps this CPU thinks something is wrong at certain RPMs and makes a waring buzz, and the shuts up at other RPM ranges?
Hmmm. I never had that type of problem. But when I removed my power steering pump, I got a continuous noise remedied by promptly removing the PSCPU.
Long shot- but check it out.
Old Jul 1, 2002 | 07:03 AM
Josepi's Avatar
Despise Enmity
This sounds like it could be the problem...one thing I have noticed is, there is NO difference in power steering at different speeds. Like I have parking lot control @80 mph...it's kinda scary. Would anyone have a pic of underneath the dash so I can try and unplug it on the way home from work?
Old Nov 3, 2002 | 01:15 AM
casio's Avatar
casio isn't here.
though slightly off topic, i remember my friend telling me about how RX7s have a steering control thats dependent on speed. like, the faster you're going, the less sensitive you're steering will be. scary, but in a safe way.
Old Nov 3, 2002 | 02:11 AM
87racer's Avatar
i heard that once you reach a certain speed your power steering shuts off as a "safety precaution". may so you dont yank the wheel and go off the side of the road. i think its just so you dont overreact at high speeds
Old Nov 22, 2002 | 11:51 PM
87seven's Avatar
underpants nomes!
Old Nov 22, 2002 | 11:56 PM
DSM
it could be a shortage in a wire, when a wire usually gets shorted it sounds like that, whether its in a car or in the house
-keegun
Old Nov 22, 2002 | 11:57 PM
SonicRaT's Avatar
Super Raterhater
that's gnomes, you dork. I'd say you either have a bad solder (wouldn't be anything new) or your powersteering is farked up, take the belt off and see if it still happens.
Old Nov 22, 2002 | 11:58 PM
dr0x's Avatar
pei > caek
Steering does get a little twitchy at high speeds... but if it scares you dont speed Ill stick to doing what I like.
Old Nov 23, 2002 | 04:48 AM
Jerk_Racer's Avatar
Mine did this when I first bought my T2. For some reason there was a non-turbo dipstick in my car. At least that's what I was told. At the time I didn't know better. Well, anyway, my oil was low and the buzzing turned out to be the low oil buzzer going off. Probably not the same issue as your buzzer, but just something to consider.
Old Nov 23, 2002 | 08:19 AM
RylAssassin's Avatar
what about it being the redline buzzer is it possible for that to be shorting out somehow??
Old Nov 23, 2002 | 10:09 AM
Aaron Cake's Avatar
Engine, Not Motor
Guys, if you notice this topic is very old. It's unlikely the original poster is still around.
However, it seems to be a problem with the power steering computer.
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
