sticking Idle rpm?
Old Aug 27, 2001 | 12:23 AM
jackc's Avatar
sticking Idle rpm?
Hi guys...
My idle likes to stick at 1150 rpm. When I hit the A/C or sometimes
move the windows up or down the idle comes down to normal rpms.
It's been like that ever since I could remember. What could be the cause and what could I do to fix this?
thanks for any replies jack
Old Aug 27, 2001 | 05:31 PM
RotaryMan's Avatar
Same problem...
Hey bro I got the same problem.....but it doesn't happen all the time....please let me know if u find out anything new ...Thanx Tony...
Old Aug 27, 2001 | 10:29 PM
dvandit's Avatar
I also have this problem now
Basically will idle at 1100 to 1200 until a load is put on the engine then it drops to slightly below normal.
Tonight I measured the voltages on the TPS and there is no change in the volateg between high idle and normal idle, so this tells me that the throttle plates are not sticking slightly open.
So I am assuming it is a vacuum leak thing?
Old Aug 27, 2001 | 11:46 PM
jackc's Avatar
Could the sticking Idle have anything to do with the 3000 rpm
stumble when cold...? Sorry not stumble-Bucking...buc....king I mean buc..ki..ng. I also have a Street port as well? Help? jack
Old Aug 28, 2001 | 07:11 AM
f2racer's Avatar
A high idle is usually a result of a leak somewhere in the airflow operations of the car. My last RX idled great between 600-700 rpm. I then did a vacuum hose job and somewhere along the lines I actually got a leak occuring in the intake manifold (you could actually feel the air escaping). Idle jumped up to 1100-1200 rpm. Could not be cured by adjusting the idle. Occasionally the idle would go down to normal (and it would do this if I intentionally dropped the revs down to 600 rpm or so by slowly engaging 1st with the brakes on), but more or less it was a consistant 1100-1200.
Old Aug 28, 2001 | 03:35 PM
ejmack1's Avatar
Lawn Ornament
Could the computer be seeing an electrical load and raising the RPM's to account for that...
Old Sep 2, 2001 | 08:30 PM
f2racer's Avatar
Computer kicks my car from 600-700 to about 700-800 rpm if the AC is on. I did a fan switch as well. Turning the fan on before the computer kicks it in results in a 500 rpm idle... Don't think that it would make the idle that high.
Old Jun 9, 2003 | 03:41 PM
mor's Avatar
mor
Anyone fix this problem yet?
Old Jun 9, 2003 | 05:05 PM
MDoMe7's Avatar
flipaholic
sorry for adding to the headaches but i think my problem may be related
my car usually idles perfectly at 700....
but once in a while when i start up the car i get a very rough idle bouncing up and down between 400-800
this happens even after i drive the car for a while, shut it off for a few minutes, then start it up again (so the engine is still warm)
i can't figure out the factor that may be causing this....any ideas?
Old Jun 9, 2003 | 08:07 PM
duboisr's Avatar
Check the Els -Electric load sensor. if it is bad then sometimes the idle will stay up . When the idle is up , then flip the ac on off on off on off . Then see if the idle goes down. try this with no other load on the alt , as lights , heater fan, wippers ect. The Els is bolted above the stock ECU .
Old Jun 10, 2003 | 10:52 AM
maxpesce's Avatar
Ex fd *****
Sound mor like a bad Idle Speed Control, The ELS only bumps rpm by 150-200 rpm
Old Jun 10, 2003 | 11:02 AM
DoingAnything's Avatar
Where did i park my car?
Can you tell me more about this ISC thing please. I really want to fix this idle problem, its so annoying to have to flip the a/c switch at every red light.
Where is the ISC located and is it like a sensor (read as: easy to work on)? Any help would be great.
Thanks.
Old Jun 10, 2003 | 03:45 PM
teamstealth's Avatar
Ozone Depleter
mine is a little weird as well...normally when warm, it'll idle 1100-1200. And then every so often for no reason it'll drop to a normal 700....i dont have a damn clue why though
-Z
Old Jun 11, 2003 | 07:17 PM
rousu's Avatar
Is the Idle Speed Control what is responsible for the 3000 rpm when started dead cold in the morning?
Is it adjustable, or a replacement item?
Old Jun 11, 2003 | 08:12 PM
Ozone Depleter
no, that is the accelerated warmup system...it can be removed though
Old Jun 11, 2003 | 08:16 PM
DaedelGT's Avatar
Uber Newb.
After replacing my FPR and putting on a nut Steve Kan (not God incarnate afterall ) forgot to install on the ACV when he did work on my car, my idle fixed itself.
Old Jun 11, 2003 | 08:18 PM
EviLPeNeviL's Avatar
Can't live without boost.
After a good warm up my car idles between 850-900rpms.
-Dan
Old Jun 12, 2003 | 10:13 PM
mor's Avatar
mor
I think I have a bad ISC. This is what I did:
1. Car warmed up. Turned off.
2. Jumped TEN and GND.
3. Started car.
4. Adjusted Air Bleed to 750 rpm.
5. Pulled off TEN and GND.
6. Idle remained the same, did not jump up to 850 rpm like it was expected to.
Is this a bad ISC?
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
