Jumping Tach...Still
Old Mar 29, 2003 | 11:27 PM
RotorMotorDriver's Avatar
Seven Is Coming
Ok, before when my tach started jumping, someone said the plugs might cause too much resistance cause they needed to be replaced and then the spark would look for an "easier way out". Well, I changed my plugs and away it went.
Well, its back. I have new wires, plugs, distributor cap, rotor, and changed BOTH ignitors multiple times. Still, whenever I floor it in a semi bogging situation (like 35-40 in 4th), the tach will jump up and then come back down. Any other time its smooth and normal. Slow acceleration, heavy acceleration, cruising, etc. Nothing does it but flooring it at "low RPMs" for any given gear. It only jumps for a second or so, then comes back to working normally. Its just agravating. Also. at the same time, it feels that something is almost intermitant about the ignition, like its dying out when it jumps, and then coming back once the tach returns to normal, but Ive checked all I can think of.
So, if you guys could work with me and help me figure this out, I would greatly be appreciative. Thanks .
~T.J.
Old Mar 30, 2003 | 12:37 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
I have the SAME EXACT problem.
Old Mar 30, 2003 | 03:17 AM
mar3's Avatar
Administrator
Remember Rob Golden's anaolgy of an engine working compared to a bicyclist? It takes more work when you're in the wrong gear to get going. The spark is not not jumping or the resisitance is so high you're getting the same effect as bad/old plugs. Time for DLIDFIS?
Old Mar 30, 2003 | 06:41 AM
browney's Avatar
Have you tried replacing the fuesable link? When my tach was jumping that was the cause.
Old Mar 30, 2003 | 09:40 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
how much does it jump, i had a friend with one that just floated all over the place wildly, the tach was bad
Old Mar 30, 2003 | 11:24 AM
Mine jumps mainly when boost starts to hit...at about 3000 it flys way over to 7000.
Old Mar 30, 2003 | 11:39 AM
MIKE-P-28's Avatar
Yeah LOL, mine does that too, mainly in 1st, have no clue why? LOL. I think it has something to do with the pedal on the right, I forgot what its for tho? anyone know?
Old Mar 30, 2003 | 12:01 PM
HAHAHA SMARTASS
Old Mar 30, 2003 | 03:37 PM
Seven Is Coming
Mine jumps different amounts. Sometimes only a few hundres RPMs, sometimes a couple thousand. Its just really random. I dont know what to do. Seriously, this bugs me, can you guys try and help?
~T.J.
Old Mar 30, 2003 | 05:59 PM
MIKE-P-28's Avatar
~T.J.
you tried replacing the cluster for just ***** and giggles, I have seen 79's do this with bad points, but not a 1000 rpms or so, also have seen 80's with igniter boxes do the little idle at 750 and the rpm guage kicks ever so often to 1200 or so but that was bad parts, this sounds like a bad tach.
Old Mar 30, 2003 | 06:00 PM
MIKE-P-28's Avatar
HAHAHA SMARTASS
still what is that pedal on the right for? I know the one in the middle makes my head hit the windshield, and the one on the left makes the engine rev, but what is the one on the right for? I know i makes that little buzzer go off... LOL
Old Mar 30, 2003 | 06:16 PM
gamble302's Avatar
roadkill hats rock
you hooked up the buzzer on that thing? oh wait if you hooked up the stock stack it would buzz on its own
Old Mar 30, 2003 | 11:17 PM
Seven Is Coming
Sounds like too much work...lol
~T.J.
Old Mar 31, 2003 | 12:07 AM
Cody's Avatar
SKELETOR!
I think its just a weird electrical system in these cars.
I notice that my voltage guage (or whatever its called) will move, almost like the tach with the revs.
If I floor it, I produce more electrical power. Craziness.
Old Mar 31, 2003 | 03:15 AM
The jumping tach may have something to do with our MSD Blaster 2 coils TJ, because I have never had this problem till after I installed them. Who knows, but it bugs the hell out of me too!
Old Mar 31, 2003 | 11:52 AM
Seven Is Coming
I had it before I installed them, thats part of the reason I bought them... Good idea though .
~T.J.
Old Mar 31, 2003 | 07:22 PM
Seven Is Coming
Just a friendly bump for the evening.
~T.J.
Old May 9, 2003 | 11:12 PM
Matty's first 1st Gen's Avatar
Boosted 7
exact same thing happens to me, but mine goes away once its warmed up.
Could direct fire help at all?
Old May 9, 2003 | 11:13 PM
Boosted 7
and just a second question, the bullet connector that attaches to under the dizzy somewhere. That has something to do with the tach right?
Old May 10, 2003 | 02:04 AM
Junia's Avatar
Uchinanchu
I had the same problem when I first got mine. It turned out to be a bad battery. I tried with my friends battery first because I'm a cheap bastard. Never had that problem since.
Old May 10, 2003 | 04:38 AM
Seven Is Coming
I dont know what the hell is doing it. Mine still does it and I have lots of modified or upgraded pieces to both my ignition and electrical systems. Im really at a loss as to what causes this.
~T.J.
Old Oct 14, 2003 | 06:16 PM
Jon017's Avatar
Do u have mechanical secondaries because that can cause the bog and sometimes jumps the tach. That is if you have mechanical secondaries and havent modified your accelerator pump.
Old Oct 15, 2003 | 02:44 AM
Gatorgunner's Avatar
I have the same problem on mine. It seems to be connected to the fuel gauge.
Sometimes my fuel gauge dies and when that happens, my tach starts bouncing all over the place.
Ive also noticed that happens on my bike as well (i know bikes and cars are different) but if i have something unplugged that shouldnt be unplugged, and the ignition is on, my tach goes nuts.
So perhapse you should check all your connections to your dash, (gas gauge, temp, oil, etc) and see if any of them are kinda shotty, or loose.
Old Oct 15, 2003 | 04:17 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
Originally posted by Cody
I think its just a weird electrical system in these cars. I notice that my voltage guage (or whatever its called) will move, almost like the tach with the revs. If I floor it, I produce more electrical power. Craziness.
Sounds to me like you've got a regulator problem there Cody. Ya might want to check that out, cause I don't think that should be happening. Perhaps VERY slightly, but not much.
Brian
Old Oct 15, 2003 | 04:20 PM
I just realized how freaking old this thread is. Are any of the problems people were talking about even relavent anymore? And why did it get resurrected?
Brian
