Air Control Valve
Old Mar 29, 2003 | 05:52 AM
HDP's Avatar
HDP
A Fistfull of Dollars!
Air Control Valve
It there a gasket kit for the air control valve?
Old Mar 29, 2003 | 05:46 PM
HDP's Avatar
HDP
Yes... no... anyone?
Old Mar 29, 2003 | 06:25 PM
JONSKI's Avatar
5yr member, joined 2001
Yes.
Old Mar 30, 2003 | 06:17 AM
HDP's Avatar
HDP
Well what are the part numbers for all the gaskets and rubber seals.
Old Mar 30, 2003 | 06:00 PM
JONSKI's Avatar
You can view the parts fiche at http://www.iluvmyrx7.com, but Mazda should have the same thing on hand to look up the parts for you.
Old Mar 30, 2003 | 08:53 PM
Garrett's Avatar
ACV Gasket
N3A3-13-996
Old Mar 31, 2003 | 09:31 AM
HDP's Avatar
HDP
I'm speaking of gaskets for the ACV itself. There are gaskets for the 2 chambers, a rubber gasket for the internal plunger, and a gasket for the airpump pipe. What are the part numbers for these?
Old Apr 1, 2003 | 03:06 PM
HDP's Avatar
HDP
ttt... help!
Old Apr 1, 2003 | 07:34 PM
puma's Avatar
canadian monster
is it in the parts list? if not, there are none, you need to buy it as an assembly. I am sure someone could sell you one for very cheap.
Old Apr 2, 2003 | 12:55 PM
HDP's Avatar
HDP
What purpose does the ACV serve? What will happen (or won't) if it's not functioning properly?
Old Apr 2, 2003 | 03:01 PM
JONSKI's Avatar
The description of the ACV's operation starts on page F-115 of the FSM. It feeds air from your airpump to your exhaust ports and main cat for cleaner emissions and catalytic converter longevity. Without it, you will have very foul emissions and your main cat will clog more quickly.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
