Got my header on, but car is acting... strange
Old Mar 28, 2003 | 11:35 PM
O 16581 72452 5's Avatar
The infamous number guy!
Well, i got my header on, my idle is messed up though, i blocked off my acv with the blocker plate it came with, i think this is the problem, i used a ton of gasket sealer in there, didn't have a gasket but my car doesn't want to idle normal, i was running the header open and it sounded like a muscle car with a cam before i put this header on, i connected a disconnected vacuum line from my cruse control and the line that is from some plastic part under the cruse control, i heard they both went together into a T then into a 4 tipped connector, hooked them up and instant air fuel ratio problems... any suggestions?
Old Mar 29, 2003 | 03:05 AM
djmickyg's Avatar
what sort of strange idle?
alot of strange idle's are from vacume leaks
Old Mar 29, 2003 | 08:12 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
when I put my header on and the block off plate, I didnt seal the block off plate well enough. Make sure its very clean and use a ton of sealant, just wipe off the stuff that gets squished out.
Old Mar 29, 2003 | 09:05 PM
Funny story, took out my block off plate, made a gasket out of a paper plate and aluminum foil put the plate on, broke a bolt off though, but with two bolts and a broken one the idle has gotten alot better... any suggestions for removing a broken bolt?
Old Mar 29, 2003 | 09:39 PM
gamble302's Avatar
roadkill hats rock
a screw exctractor set fomr home depot is like 10 bucks, you'll use it else where too. need a drill to do it of course, that is assumeing you can get a drill in there though doh
Old Mar 29, 2003 | 11:11 PM
RotorMotorDriver's Avatar
Seven Is Coming
Take the block off plate off if it broke off flush with the block off plate, then you might be able to get in there with vise grips .
~T.J.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
