88 RX-7 Needs Struts
Old Mar 25, 2003 | 11:18 AM
swohrx7drvr's Avatar
I own a 1988 GXL with 100K miles on it. It needs new struts. The dealer is quoting about $1,000 to replace them with the OEM struts.
Are there any cheaper alternatives? I would do it myself, but it looks like I need a hydraulic press to compress the springs.
Any suggestions out there?
Old Mar 25, 2003 | 12:36 PM
DomFD3S's Avatar
Mod Powers...gone!
I would suggest that you search the 2nd gen section as well as in this section (as this is a VERY frequent topic). Use keywords such as shocks/struts, etc.
Also, look into AGX shocks. That should help you.
Old Mar 27, 2003 | 10:27 PM
Does anyone know which aftermarket struts will be compatible with the auto adjust suspension system on the 88 GXL?
Old Mar 28, 2003 | 03:27 AM
ARD T2's Avatar
None. You get rid of that **** and buy KYB AGX struts. Basically just unbolt the actuator from the top and remove the suspension.
AGX's are manual adjustable and give you 4 settings up front and 8 in the rear. These can run you around $400.00 or slightly less for the whole set. These are great struts.
Rishie
