Need some info on 1st gen clutch set up
Hey guys, sorry for the newbie type questions but I dont know much about 1st gens.
Can someone tell me if the clutch system on any of the first gens is mechanic or hydro.
I'm brainstorming up a rotary project and will be in need of a mechanical clutch. I'm hoping one of the 1st gens had one
Thanks,
STEPHEN
Thanks,
STEPHEN
no, its actually not going to have a transmission. I'm brainstorming a one speed belt driven (similar to motorcycle) go cart. It'll be belt driven off the flywheel assembally directly to the axle. I just need a clutch so when I'm at idle the rotating flywheel wont keep turning the wheels.
I dont want to install all the hydrolic ****. Didnt they use to just make mechanical clutches that didnt have all that ****???
STEPHEN
STEPHEN
Not on the RX-7. It sounds like you need either a centrifical clutch or a fluid coupled clutch of the type you would find on a go-kart, but with a higher load capacity. Such a clutch would not have any external control (clutch pedal etc.) and simply be engaged by RPM. There are some race cars (F5000??) that use that arraingement, and what are/were the Malibu Gran Prix cars using (single rotor engines)??
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
rx8volks
Canadian Forum
Aug 13, 2015 04:55 AM
